ᐅ Is there a maximum load capacity for benches made from Kallax units?
Created on: 9 Feb 2020 08:37
Chenman
Chenman
9 Feb 2020 08:37
I have been wondering for some time whether there is a clearly defined maximum load capacity for the benches made from the IKEA Kallax shelving unit. Specifically, I am interested in the weight limits that should be observed when using such a bench—especially when several people are sitting on it at the same time or when the Kallax shelving unit is used both as storage and as a seating surface.
This question is important because I want to build a Kallax bench myself and want to ensure that the construction is stable and durable.
Does IKEA provide specific information on this, or are there community experiences and recommendations that I should consider?
Thank you very much for your insights!
marcosku52
9 Feb 2020 10:23
Chenman schrieb:
whether there is a clearly defined maximum load capacity for the benches built from the IKEA Kallax unit.
Hey Chenman, good question! 😊
As far as I know, IKEA specifies a load capacity of about 13 kg (29 lbs) per shelf for the Kallax unit – but this applies to shelving compartments, not benches. The load capacity of the entire unit used as seating obviously depends a lot on how it’s reinforced and how well the seat surface is fixed.
If you simply place a large seat on top and use the unit without reinforcement, I would allow a maximum of three people or 200 kg (440 lbs) – and even then, cautiously. It’s safer to keep it a bit lower to avoid creaking or breaking. Especially with older units, material wear tends to accumulate.
My advice: If you want it sturdier, add an extra bottom panel underneath to better distribute the weight and secure everything firmly together. This way, the Kallax unit quickly turns into a stable bench that can comfortably handle a nice chat over coffee and cake. 😉
Does anyone here have better experience or constructive tips?
draleo
10 Feb 2020 14:52
marcosku52 schrieb:
As far as I know, IKEA specifies a load capacity of about 13 kg per shelf for the basic Kallax unit
Exactly, that is correct. IKEA’s official specifications state a maximum load capacity of 13 kg (29 lbs) per shelf with evenly distributed weight. It is important to note that the Kallax system was not designed to be used as seating furniture.
Chenman schrieb:
whether there is a defined maximum load capacity for benches built from the IKEA Kallax shelf unit
IKEA does not provide a specific maximum load limit for benches made from Kallax units, as the shelving is intended as a storage system. Things to consider include:
- Stability largely depends on modifications (reinforcements, seat surface)
- The wood-based materials and joints are not optimized for dynamic loads such as seating weight
Typical user experiences from various forums and DIY groups recommend planning for a total weight of around 150–200 kg (330–440 lbs) if a Kallax unit is used as a bench and appropriate reinforcements are installed. Without reinforcements, stability and thus load capacity can be significantly lower and may permanently damage the shelving elements in the worst case.
Summary: There is no official maximum load rating for Kallax benches provided by IKEA. Load capacity depends primarily on the individual bench construction. It is recommended to limit the weight to a maximum of 200 kg (440 lbs) and implement stability measures.
chen67
11 Feb 2020 09:07
draleo schrieb:
It is recommended to limit the weight to a maximum of 200 kg (440 lbs) and to implement stability measures.
Great summary – thanks! 🙂
I built my own Kallax bench with a thicker wooden board as the seat surface on top, and the shelf is fixed to the wall using brackets. The difference was clearly noticeable – when two people sat on it (around 160 kg (350 lbs) total), there was no creaking or wobbling.
Kallax isn’t the most durable wood, but with a few tricks, you can create a comfortable seating area. One more tip: for the seat surface, it’s best to use a plywood panel or furniture board at least 18 mm (0.7 inches) thick to support the weight. Also, make sure to add reinforcement under the seat.
What also helps me: fitting the shelf’s feet with larger rubber pads. This distributes the load better on the contact points with the floor and makes the bench stand more securely.
Hope this helps those considering a project like this! 😉
JONKO
12 Feb 2020 16:31
Chenman schrieb:
Does IKEA provide specific information on this, or are there community experiences I should consider?
I completely understand wanting to be on the safe side. It’s also good that draleo mentioned the issue of dynamic loads—that’s often underestimated.
About a year ago, I built a Kallax bench and later regretted not taking load capacity seriously enough. Two adults and a child sat on it together, and after a short time, the shelf panel already showed slight deformation.
It wasn’t dangerous, but it was unpleasant and indicated that the load limit had been reached.
My advice: If possible, better to be cautious and plan for reinforcements. Also, consider the weight not just as a static problem, but think about durability over months and years—the more constant load, the sooner the materials will wear out.
Therefore, my suggestion is 150 to a maximum of 180 kg (330 to 400 lbs) if no additional measures are taken; otherwise, the risk can be kept reasonably low.
Of course, the maximum value can vary depending on the usage scenario, but a cautious approach pays off.
Looking forward to more experiences!
