IKEA-Experte18 Jan 2016 17:16Hello, there used to be Pax wall cabinets, but that won’t help you. You can put a Faktum base cabinet on top (available in your area only until April?).
Herr rossi18 Jan 2016 21:43Hi Steph,
if you’re handy and have a carpenter who can make precise cuts, get a second Pax and cut it to the missing length. If you use the 236cm (93 inches) high Pax, get a 201cm (79 inches) one as well and cut it in half. Leave out the base and the bottom panel. Then attach the top section from the inside using brackets or a strip. It gets a bit more complicated with the doors because you’ll need to redrill the hinge holes. This method has always worked for me.
Best regards, Herr rossi
