ᐅ Is it normal for BILLY to sag slightly when loaded?
Created on: 20 Aug 2023 09:37
faleonard
faleonard
20 Aug 2023 09:37
I have a question about the IKEA BILLY bookcase that has been on my mind recently: Is it normal for the BILLY bookcase to sag slightly when loaded with books or other items? Specifically, my middle or lower shelves seem to bend a little under weight. I’m wondering if this is simply a characteristic of the materials or design, or if there might be an issue with the assembly or the load capacity.
I have had the bookcase for about 6 months and store books of moderate weight on it. Have you had similar experiences or any tips on how to prevent sagging? Спасибо in advance!
nedagla
20 Aug 2023 09:56
Hello faleonard! It’s great that you brought up this topic! 🙂
I’ve noticed the same thing with my BILLY shelves. Especially when I place a lot of heavy books on them, the shelves often sag, but I think that’s pretty normal since the shelves aren’t designed for heavy loads! There are small metal pins holding the shelves, and over time they can give in a bit.
Maybe you could consider placing a thin sheet of plexiglass underneath or adding an extra board as reinforcement? That helped a lot for me. But don’t worry, some sagging is not unusual! Keep it up, I’m sure you’ll find a good solution!
Elias
20 Aug 2023 10:14
nedagla schrieb:
Sagging is nothing unusual!
Thanks for the tip!
I really understand the concern that faleonard has. Sometimes you worry that something might break or that you’re using the furniture incorrectly. I have a BILLY myself, and one of my shelves also sags slightly when it’s fully loaded. For me, that actually gives the impression that the shelf is “alive” and somewhat flexible – although I realize that’s not a comforting thought for everyone. 🙂
It’s probably important not to exceed the weight limits and to always install the shelves straight. faleonard, have you tried flipping the shelves or positioning them differently?
About how much load does each shelf carry approximately?
Ethan
20 Aug 2023 11:02
Hello faleonard,
I can explain this in a bit more detail. The BILLY shelf is mainly made of particleboard with a decorative laminate. These materials naturally have some flexibility and a maximum load capacity, which IKEA specifies as around 30 kg (66 pounds) per shelf, depending on the shelf’s length and width.
If you notice that the lower or middle shelves are sagging, there could be several reasons:
1. Excessive load: Books are quite heavy, and if many are concentrated on one shelf, it can exceed the load limit.
2. Uneven load distribution: If the books or items are all placed in the center, it puts more stress on the shelf than an even distribution.
3. Installation issues: If the metal pins are not properly seated or there is no wall anchoring, the shelf can become unstable.
My recommendation: First, check that all metal supports are firmly in place, distribute the load evenly, and consider upgrading the shelves with inserts made from sturdier material.
A question for you: Have you fixed the shelf to the wall? That increases stability and reduces sagging.
INGRID34
20 Aug 2023 11:29
Slight sagging is normal with BILLY and other particleboard shelves.
Important: Distribute the load evenly, do not forget wall mounting, and do not exceed the maximum load capacity.
For heavier loads, cross braces or sturdy replacement shelves can help.
Laukau5
21 Aug 2023 14:03
Hello faleonard,
I will go into some detail here because the topic is quite technically interesting. The BILLY shelf is made from medium-density fiberboard (MDF) or fiberboard, which has limited flexibility and load-bearing capacity. The standard shelves are not fully reinforced and rest on metal pins. These pins are sturdy, but under higher weights and over longer periods, they can bend slightly, which shows as sagging.
I recommend the following steps:
1. Measure the load: Try to estimate the weight on individual shelves. For example, standard paperback books weigh about 0.3 to 0.5 kilograms (0.7 to 1.1 pounds) each. If you have around 30 books on one shelf, you can estimate approximately 15 kilograms (33 pounds).
2. Load distribution: Check if the heaviest items are placed in the middle or at the edges. A central load causes longer leverage and increased bending.
3. Ensure wall mounting: Securing the shelf to the wall is essential because it prevents tipping or unnecessary strain.
4. Reinforced shelves: Replacement shelves made from thicker panels (e.g., 18 mm (0.7 inches) MDF instead of 12 mm (0.5 inches)) or with metal reinforcements can solve the problem.
I would be interested to know if you have tried different loads or shelf compartments and whether the sagging occurs equally on all of them. Also, how the shelf changes over time, meaning if the sagging increases.
Best regards!
