ᐅ Is the Ikea PAX system also suitable for use in damp rooms?
Created on: 18 Mar 2015 08:17
tausnu
I am planning to install the Ikea PAX wardrobe system in one of my damp rooms—specifically in the bathroom, which does not have a direct shower but is considered a damp room due to daily bathing and the resulting humidity. My main question is: Is the Ikea PAX system suitable for use in damp rooms?
I have read that furniture made from wood-based materials can generally cause issues because moisture can damage the material, cause swelling, or promote mold growth. However, I really like the PAX wardrobes because of their flexibility, modular design, and value for money.
Are there any experiences or insights regarding whether PAX with protected surfaces—such as lacquer or laminate—can withstand such an environment over the long term?
What about ventilation, distance from the wall, or special protective measures?
Thanks for your assessments!
tausnu
19 Mar 2015 09:20
FAZAR schrieb:
What is the exact humidity level in your bathroom, and are there radiators or ventilation installed?
Thank you for the detailed response! My bathroom has an average humidity level of about 60-70% after showering, but it decreases well within 30-40 minutes thanks to the window. There are indeed ventilation options available, and a small radiator is also installed. The cabinet won’t be exposed to direct water splashes; it would be placed on the wall opposite the sink.
I find your advice regarding the distance from the wall and sealing the edges very helpful. Thanks also for the tip to use silicone or paint – I will give that a try.
The goal is to be able to use the system long-term – if it holds up reasonably well under these conditions, that would already be a success.
I’ll get back to you once I have it set up!
HORST41
20 Mar 2015 11:15
Hello!
I completely understand how frustrating it is when you can’t use a great system like Pax due to environmental conditions.
In my own experience, I used Pax in a similar bathroom. I made sure to leave extra space from the wall and planned for enhanced ventilation. Additionally, I protected the edges with clear varnish.
It has held up for 1 year now, but I didn’t place it in the dampest areas and avoid water splashes.
I’m optimistic that with the precautions mentioned, this system can definitely be used in wet rooms – just don’t approach it too naively. Good luck to you too!
maureo
20 Mar 2015 12:44
PAX is not designed for wet rooms. You can use sealing and leave some space, but it will not hold up in the long term. It is better to look for another solution if you have many moisture cycles.
Jackson
21 Mar 2015 07:28
HORST41 schrieb:
It has lasted for 1 year now – however, I did not place it in the wettest spots and avoid water splashing on it.
Exactly! You can’t work miracles – but with small measures like these, durability is extended. Like an umbrella in the rain, even if it’s not completely waterproof, it still holds up quite well ✌️. Good luck moving forward!
