I’m considering getting a Brimnes piece of furniture from Ikea because I plan to modify it for a DIY project. My question is: Is the Brimnes range from Ikea suitable for DIY modifications?
I’m mainly interested in the quality of workmanship, material durability, and how easy or difficult it is to make changes to the furniture, such as redesigning, adding components, or improving functionality.
Has anyone had personal experience with Brimnes furniture in this context? Are there any things to watch out for, or is this furniture generally not suitable for conversions?
Thanks in advance!
Thanks in advance!
The Brimnes carcass is solidly constructed for its price, although it should be noted that it is mostly made of particle board with a foil finish. These materials tend to be less durable when frequently assembled and disassembled or subjected to heavy mechanical stress from major modifications.
For smaller adjustments, such as installing LEDs or cutting openings, Brimnes is well suited. If you plan to significantly alter the furniture—such as completely changing the interior or enlarging it—you should ensure that stability is improved with additional support elements.
I also recommend properly preparing the surfaces before any modifications, for example with edge protection or paint, as the foil finish can be easily damaged.
Traman4 schrieb:
Brimnes is generally considered mid-range.I wouldn’t fully agree with that. Mid-range is a fairly vague term. It’s better to be more specific, as the Brimnes series includes various pieces of furniture with components of differing durability.
Additionally, the suitability for DIY modifications largely depends on the purpose of the modification. For example, if the focus is on surface finishing or installing accessories, the standard quality of workmanship might be irrelevant. For structural or mechanical alterations, the cabinet frames should be examined more carefully.
blapau schrieb:
For minor modifications, such as attaching LEDs or cutting out recesses, Brimnes works well.That sums it up nicely. The critical factor is the material thickness. You shouldn’t assume that the furniture can be altered indefinitely without losing stability.
My recommendation: before making any changes, conduct a thorough analysis of the individual components and make a list of planned modifications. In my experience, touch-ups and minor extensions work best, while major alterations tend to be more problematic.
Some time ago, I modified a Brimnes wardrobe by changing the back panel and adding extra shelves. What was important to me:
- The back panel is usually made of thin hardboard, so it needs to be handled carefully, and reinforcements may be necessary.
- For the shelves, I installed additional supports because the standard shelf holders were not strong enough for my heavy use.
- However, the material is easy to drill and saw, which is a big advantage for DIY projects.
Conclusion: Brimnes is suitable for DIY modifications as long as you respect the material limits and use additional measures.
BOSULE schrieb:
Conclusion: Brimnes is quite suitable for DIY modifications, as long as you respect the material limits and apply additional measures.I agree with this.
I would add: Brimnes works well for simple adjustments, but for more complex custom builds, it’s better to use sturdier furniture.
