ᐅ Include the width of the Pax wardrobe from Ikea in the floor plan.
Created on: 31 Mar 2022 09:30
Katha_92
Katha_92
31 Mar 2022 09:30
It is very important to me that the IKEA Pax wardrobe fits into the walk-in closet. According to our planning, the Pax is 2.72 m wide (9 ft). Should I make the distance between the walls exactly 2.72 m (9 ft) wide, or do you usually allow some clearance? If yes, how much?
Does anyone have experience with this?
Thanks.
Peter Pohlmann
31 Mar 2022 09:39
You don’t design a room around the furniture, but rather the furniture around the room.
If you want to install a Pax wardrobe, that’s fine. However, the wall should be about 6 cm (2.4 inches) wider, so 2.78 m (9.12 ft). But then you’ll always have dust and dirt collecting in the gaps, and it’s hard to clean. Personally, I would make the wall 3 m (9.84 ft) wide. That way, you can clean on both sides, and if Ikea ever changes the dimensions or goes out of business, you can still fit another wardrobe.
kati133731 Mar 2022 09:53
Katha_92 schrieb:
It’s really important to me that the Pax wardrobe from Ikea fits into the walk-in closet. The Pax is planned to be 2.72 meters wide (9 feet). Should I make the space between the walls exactly 2.72 meters wide (9 feet), or do you usually allow some extra room? If yes, how much?
Thank you.
We did the same in our current house, planning for a 3-meter (10 feet) Pax to fit.
We had the wall built exactly that length.
I would recommend allowing some extra space—at least about 20 centimeters (8 inches).
Unless, like us, you want to reach behind the wardrobe just to turn on the lights. 😀
Katha_92
31 Mar 2022 10:55
Peter Pohlmann schrieb:
You don’t plan a room around the furniture, but the furniture around the room.
If you want to install a Pax wardrobe, that’s fine. But then the wall should be 6 cm (2.4 inches) wider—so 2.78 m (9.1 ft). However, you’ll always have dirt and dust in the gaps and it’s hard to access. I would make the wall 3 m (9.8 ft) wide. That way you can clean on both sides, and if Ikea changes the dimensions or goes out of business, another wardrobe will fit.
Thanks! Yes, that is correct, but Ikea doesn’t offer customized sizes, so we have to adapt to theirs.
Should 6 cm (2.4 inches) of clearance be enough for a precise fit? Thanks.
dab_dab
31 Mar 2022 11:25
When planning, please also consider the other trades: in addition to the electrical installation already mentioned by @kati1337, I would like to mention the controlled residential ventilation valves, baseboards, door frames, etc.
Katha_92
31 Mar 2022 11:55
dab_dab schrieb:
When planning, please also consider the other trades: in addition to the electrical installation already mentioned by @kati1337, I would like to mention the controlled ventilation valves, baseboards, door frames, etc.
Thanks. Controlled ventilation valve is a good tip!
Does anyone else have experience with tolerance or clearance around the walls?
