ᐅ In my older house, the Kallax shelf never fits flush against the wall. Any tips?
Created on: 29 Jun 2017 19:32
ChengarretC
Chengarret29 Jun 2017 19:32Hello everyone, I have a problem that has been bothering me for some time in my older apartment: my Kallax shelf never sits flush against the wall – there’s always a small gap or it wobbles slightly. Unfortunately, the walls are not perfectly straight, which I understand from the masonry, but even with different adjustments, it doesn’t get any better. I have tried rotating the shelf, using felt pads, and even tried leveling the wall slightly with small blocks. However, none of this leads to a stable result. My question to you: Do you have any tips or experience on how to get the Kallax cleanly and securely against the wall in an older building? Are there any tricks with shims, special anchors, or small adjustable feet that you could recommend? Thanks in advance!
Chengarret schrieb:
My Kallax shelf never sits properly flush against the wall – there’s always a small gap or it wobbles slightly.At first, this problem might seem trivial, but it’s often not the case in older buildings. It’s important to know whether your floor or wall is uneven. Especially walls in older buildings are rarely perfectly vertical. Have you checked how much the wall deviates using a spirit level and an angle finder?
If the wall isn’t straight, the shelf will never sit completely flush. I recommend using adjustable furniture glides under the shelf feet instead of simple pads. This way, you can compensate for differences individually.
It also helps to secure the shelf to the wall to prevent wobbling. Of course, you should make sure the fixing is stable – plugs and screws must be suitable for the masonry.
Could you describe the extent of the unevenness in more detail? Is it 1-2 mm or several centimeters (inches)?
BLAKEO schrieb:
Here, I don’t recommend simple pads, but rather adjustable furniture glides that you can mount under the shelf feet.Yes, furniture glides are the best solution. Alternatively, you can use thin wooden strips to compensate for minor unevenness. Leaving an air gap at the wall is often unavoidable in older buildings.
I really understand your problem; those old building walls can be quite frustrating sometimes.
What helped me was a combination of small washers under the feet of the shelf and securing it to the wall with brackets. This way, the shelf no longer wobbles, and the washers compensate for unevenness.
Whenever I had wobbly furniture, it always took a bit of courage at first because you don’t want to “damage” anything or make it too noticeable. But it really brings peace of mind.
Maybe you also have the option to slightly cushion the floor with carpet or non-slip mats. That can also help stabilize wobbly furniture.
Keep your chin up; many people in older buildings face this problem – it’s just that hardly anyone talks about it so openly 🙂
