ᐅ Installing IKEA METOD Sliding Door Systems: Modern and Space-Saving Solutions
Created on: 13 Apr 2020 08:12
pumaxim
I am currently planning the installation of an IKEA METOD sliding door system in my new kitchen and am looking for helpful tips on how to install this modern system as space-saving and stable as possible. I am particularly interested in the challenges of adapting the door profiles to uneven walls or tight spaces.
Since I want to use the sliding doors mainly where traditional hinged doors take up too much space, I am wondering: What proven techniques or accessories do you recommend to make the doors look modern while ensuring perfect functionality?
Also, it would be interesting to learn how you deal with any clearance or minimum measurements in the track system, so the doors don’t warp or stick over time.
Thanks in advance for your input!
pumaxim schrieb:
I’m particularly interested in the challenges of fitting door frames to uneven walls or tight spaces.I can relate to that, as I had similar concerns when working on my kitchen. What helped me was:
- Patience during installation and trusting the adjustment options the system provides.
- Detecting and compensating for small irregularities very early to avoid frustration later on.
The system is actually very well-designed, but I was still a bit apprehensive about the precise work involved. In the end, it will definitely be worth it—these solutions really save space and look very modern.
liste schrieb:
I would like to question here whether two fixed points are really enough.That’s a valid point, thanks for following up.
In fact, it depends on the length of the track and the weight of the doors. For longer tracks or heavier fronts, a third fastening point is definitely advisable. IKEA itself recommends a specific number of screws depending on the system.
Another tip: Before installation, check whether the material might warp, then decide about additional fixing points.
If you want to be on the safe side, you can use more screws than recommended; this will increase stability without any downsides.
