Hello everyone, I have some IKEA Metod kitchen cabinets where the screws have recently started to loosen, which is obviously not ideal for stability. My question is: How can I professionally fix loose screws on IKEA Metod furniture without compromising stability or warranty? I am particularly interested in whether there are special techniques or materials to safely and permanently retighten them, and if certain tools are especially recommended. If anyone has experience with retrofitting or reinforcing the screws, I would greatly appreciate any tips, especially on what to do with the often very small and specialized fittings. Thanks in advance!
I wonder if the loosening of screws in Metod modules should also be seen as a design issue. IKEA often uses particleboard, which is not the most durable material for permanent fastenings.
Have you checked whether the screws were properly and precisely screwed in, or if the wood is already giving way significantly? It could also be that the original load or installation was not optimal.
It would also be interesting to know if you have tried using larger dowels or alternative fasteners that provide greater long-term stability.
I believe the focus should not only be on retightening but also on finding ways to make the joints more robust over time.
pinbo schrieb:
I wonder if the loosening of screws in Metod modules should also be considered a design flaw.Exactly my thought. IKEA probably didn’t develop the most robust connection solutions. The particleboard kitchen units are often not designed for heavy use but rather for low cost and quick assembly. If you want something truly durable, it’s better to focus on solid wood or more professional systems.
In my opinion, repairing loose screws is often only a temporary fix to give weak points a bit more stability. Ultimately, the main question is whether such a repair is worthwhile at all or if it’s better to opt for other types of furniture.
Muso4 schrieb:
In the end, the main question is whether such a repair is even worthwhile or if it’s better to choose other types of furniture.That is certainly an important consideration. However, there are reasons why many of us use Metod: adaptability, availability, and value for money. That’s why I’m mainly interested in a practical repair solution.
Thanks for the contributions so far, especially giabau’s guide. If anyone has additional tips specifically for the combination of Metod cam locks and the particleboard material used, please share!
