ᐅ Ikea Metod: How can I optimize storage space in base cabinets?
Created on: 26 Oct 2023 08:17
jobrenton
jobrenton
26 Oct 2023 08:17
Hello everyone, I am currently working on optimizing storage space, especially in the base cabinets of the IKEA Metod system. My focus is on maximizing the available space, particularly in the drawers and the compartments behind the doors, without losing overview and accessibility. Does anyone have tips for practical interior fittings, such as additional shelves, organizers, or alternative pull-out systems? Any advice on increasing load capacity or smart compartmentalization to avoid losing or wasting smaller items would also be very helpful. It would be great if someone with hands-on experience could share what solutions have actually worked in everyday use with Metod kitchen base cabinets. Thanks in advance!
Gafiel
26 Oct 2023 09:46
Hello jobrenton, your question gets right to the heart of practical use when it comes to Metod base cabinets. Basically, I recommend first accurately measuring the actual interior dimensions of each base cabinet, as depth and height can vary—especially with corner or tall cabinets. Here are some detailed tips and technical points to consider when optimizing:
- Shelves: The adjustable shelves in Metod are very useful, but it’s important to choose sturdy shelves at least 16 mm (5/8 inches) thick to increase load capacity. There are also special glass shelves available if you want better visibility.
- Internal pull-outs or drawers: Especially for wide base cabinets, internal pull-outs are a game-changer as they greatly improve access to the rear area. It’s worth focusing on high-quality runners; although IKEA uses reliable ones, upgrading to soft-close and full-extension runners makes usage more comfortable.
- Organizers & modular boxes: There are modular organizers made from plastic or bamboo on the market that can be perfectly cut to size for the drawers. Small insert boxes are great for items like spices or kitchen utensils and can be fixed inside pull-outs or on shelves.
- Utilizing the inside of cabinet doors: Installing hook rails or narrow containers here is recommended to safely store frequently used small items without reducing the main storage space.
- Load capacity & material: It’s important to distribute weight evenly and place heavy items in the lower drawers, as otherwise the runners may wear out more quickly.
I’d be interested to know the main use of your cabinets (pots, pantry items, dishes?) so the interior layout can be better customized. Precision in planning is essential, especially if you want to make modifications later on.
tyson51
26 Oct 2023 11:22
Good morning,
I would like to briefly support Gafiel’s detailed explanations and add a few practical tips that have proven useful in daily use:
- I recommend using drawer dividers made of wood or plastic, which fit perfectly into the IKEA Metod system drawers and prevent small items from shifting.
- Additionally, full-height storage boxes behind doors are a good way to safely store bottles or tall containers.
- I also find it important not to try to store all utensils in every base cabinet but to define clear zones – for example, pots and pans in one cabinet, supplies in another. This helps prevent clutter.
Finally, a note: Many underestimate how much a second or third internal drawer can improve functionality. It costs a bit more but makes operation significantly more efficient.
I hope this is helpful.
kieran
27 Oct 2023 07:54
Gafiel schrieb:
Pull-out shelves or drawers: Especially in wide base cabinets, pull-out shelves are a game changer because they greatly improve access to the rear area.
This is a very important point that I would like to emphasize again. With the IKEA Metod system, the problem often is that the back of a base cabinet is difficult to access, which effectively reduces storage space. Pull-out shelves or drawers solve this issue efficiently.
In addition, I recommend paying attention to whether the shelves are perforated (e.g., wire shelves), which provides ventilation—especially useful in pantry cabinets for vegetables or dry goods.
- Installing pull-out wire baskets is also worthwhile because they improve visibility and help organize smaller items.
- If there are height restrictions: If the existing shelves limit the drawer height, you can use combined systems (e.g., a tall pull-out drawer with a fixed shelf above it).
Another consideration is using modular organizer systems that can be customized individually and easily reconfigured if needs change.
In summary: Optimizing storage is always a balance between accessibility, visibility, and maximum utilization. Therefore, it is advisable to plan carefully in advance what will be stored and how often it will be accessed.
TRADI
28 Oct 2023 15:03
Hello jobrenton and all readers,
I’m bringing up this topic again because when using IKEA Metod base cabinets, it’s often the details that make the difference. Here are some basic recommendations, especially for beginners in kitchen planning:
- Measuring: Take precise interior measurements before definitively purchasing any accessories. The difference between cabinet carcass dimensions and interior measurements for various cabinet types should not be underestimated.
- Accessories: IKEA itself offers a good range of shelves, pull-outs, and small inserts that are seamlessly compatible. Investing in properly fitting components is worthwhile.
- Organization: In small kitchens, it makes sense to choose multifunctional storage solutions (e.g., knife drawers with lids or pull-out spice organizers).
- Load capacity: To prevent damage, avoid storing excessively heavy or large items in drawers that are too small.
- Installation: If you feel uncertain about the installation, I recommend professional assembly, as this impacts both the stability and long-term usability.
In all cases, patience and careful planning are usually the best helpers. If you’d like, I can also suggest a list of accessories that are often underestimated.
