ᐅ Ikea Metod: How to Build Kitchen Islands with Work and Seating Areas Yourself?
Created on: 22 Jun 2024 18:47
Fotereo
I am planning to expand my kitchen with a self-built kitchen island using Ikea Metod base cabinets. The island should provide a generous work surface as well as a comfortable seating area. I am particularly interested in the following details: How can I combine and reinforce Metod base cabinets so that the island is stable enough to be used not only as a workspace but also as a dining or breakfast area?
Furthermore, I would like to know which countertops are recommended for creating a seating area on one side without the countertop edge sagging or getting damaged. Are there any installation or connection details that should be considered specifically when building a kitchen island with seating?
I would appreciate any experiences, tips on material selection, assembly details, or general advice regarding stability. Thanks in advance!
I have to admit, I was initially unsure whether a self-built IKEA Metod kitchen island with a seating area would live up to expectations.
What helped me: Before assembly, I reinforced the individual cabinets much more securely with brackets than IKEA recommends, doubled some screws, and added small metal connectors to minimize any wobbling.
The seating surface, made from 4 cm (1.6 inch) thick beech wood, was further strengthened underneath at the support points with a U-shaped steel profile. This gave me mainly psychological confidence. After that, everything felt as solid as you would expect from a high-quality kitchen island in a furniture store.
So my tip: Don’t skimp on reinforcement materials and think about solutions beforehand rather than having to handle a shaky island nervously later on. I understand that this requires an investment of time and money, but it saved me a lot of frustration.
PeoDaniel23 Jun 2024 13:49Hello Fotereo,
I would like to add that when choosing the feet or base for the island, stability should also be considered. Ikea offers adjustable Metod base feet, but on the seating side, I would recommend adding at least two sturdy support legs with floor contact, made of metal or solid wood.
It is also important that the seating surface is installed without any play. Even slight movements will cause noise and material fatigue over time.
If you are thinking about kitchen lighting for the island: a solid wood countertop allows for easy installation of an integrated LED strip without compromising stability.
My conclusion: The challenge is less about the assembly itself and more about consistently reinforcing and securing the moving parts.
koduga schrieb:
So my tip: Don’t skimp on reinforcement materials and think about solutions beforehand rather than nervously protecting the island later.Absolutely right! Additionally, I would like to point out that when cutting the countertop, you should already ensure at the time of ordering or in the home improvement store that the edges are smooth and clean. Unevenness and small cracks are weak points on overhanging seating surfaces and can deteriorate quickly.
It’s also worth carefully planning the locations of the countertop’s fastening points so that the screws don’t end up where legs or chairs will be placed under the seating area later. This keeps everything ergonomic and free of obstructions.
Do you have any experience with special edge protection profiles for solid wood countertops that can be used on a seating island?
