ᐅ How can I build IKEA Metod kitchen islands with accessible, barrier-free access?
Created on: 5 Feb 2021 09:23
meobla
I am planning to build an IKEA Metod kitchen island myself, with a special focus on ensuring barrier-free access. My question is: What specific adjustments and configuration options are available with IKEA Metod to create a barrier-free kitchen island, particularly regarding height, depth, and wheelchair accessibility? Additionally, I would appreciate advice on which modules are especially suitable, where I might need to make custom modifications, and how to implement the whole setup so that it is both stable and functional.
Donar34
6 Feb 2021 08:19
Regarding stability: Removing the base supports from Metod significantly increases the demands on load distribution. The standard IKEA legs are usually 10 cm (4 inches) high and are not designed to withstand high lateral forces if the island area remains accessible underneath.
I recommend:
- Using sturdy steel or aluminum profiles as additional standoffs beneath the countertop.
- Cross bracing between the base cabinets to increase rigidity.
- Securing the countertop to the wall or ceiling, if possible, for extra support.
The modular carcasses provide a good foundation, but without adequate floor-level support, the island will be unstable. Custom metal frames are therefore a good solution.
Josan
6 Feb 2021 08:56
meobla schrieb:
Are there any experiences regarding whether the screw-in feet from IKEA are sufficient or if custom metal constructions are necessary?
The IKEA feet are primarily designed as adjustable plinth heights and are less intended as load-bearing elements for barrier-free concepts. For a kitchen island with a clear space underneath, many recommend installing additional steel frame structures. These provide advantages in supporting the countertop load, especially if it is made of stone or solid wood, which are very heavy.
In practice, you can also use wooden battens for reinforcement, but they offer less stability than metal profiles and may weaken over time. The metal frame can also be relatively easily screwed to the existing cabinets and should provide the necessary stability.
Nauman5
7 Feb 2021 12:04
I think making a kitchen island accessible might sound complicated at first, but with the right tricks, it’s actually quite easy. Just get a little creative: imagine your island like a small piece of furniture standing on sturdy legs – basically your adult kitchen treehouse 😉
A few tips: use light colors and clean lines for the design, as this makes the space feel lighter and more accessible. Also, leave enough clearance around it so no one using a wheelchair bumps into it while cooking. For the Metod cabinets, simply get some adjustable feet and experiment with the measurements. This way, the island will not only be accessible but also stylish and inviting.
meobla
8 Feb 2021 07:13
Great, I understand that in addition to the Metod cabinets and IKEA legs, I should build a custom frame for stability, ideally using aluminum or steel profiles, and attach the countertop directly to this frame. I will also adjust the height to about 75 cm (30 inches) and allow for at least 70 cm (28 inches) of clearance underneath. I plan to design the island so that it is barrier-free accessible from one side, while the other side offers storage with drawers.
My next question is whether there are any technical limitations when modifying the Metod components, for example regarding the width of the modules or the thickness of the countertops, that I need to consider if the island is going to be open and have legroom underneath?
Donar34
8 Feb 2021 07:50
meobla schrieb:
My next question would be whether there are technical limits when modifying the Metod units, for example regarding the width of the modules or the countertop thickness, that I absolutely should keep in mind
Yes, there are limits: Metod units come in standard widths of 20 cm, 40 cm, 60 cm, and so on. For a stable island, it is advisable not to use modules wider than 80 cm (31.5 inches) without additional supports, as the cabinets can otherwise sag. The depth is usually 60 cm (24 inches), which typically fits well with a countertop overhang – for the countertop, you should plan for a thickness of 3–4 cm (1.2–1.6 inches), maximum 5 cm (2 inches), otherwise the island becomes too heavy.
The countertop must also be adapted to the knee space: overhangs should not be too large to avoid the risk of breaking. Solid wood or stone countertops are often more stable here than a thin particle board with laminate.
