ᐅ Quickly Modify and Adapt IKEA METOD Cabinets During Renovations
Created on: 25 Sep 2020 18:17
DUWAYNE
I am facing the challenge of not only reorganizing my IKEA METOD kitchen cabinets during a home renovation but also modifying them quickly and flexibly to fit new room layouts. I would like to rely on proven methods that allow fast adjustments without having to completely dismantle everything or invest in expensive new components.
I am especially interested in how you modify the cabinets to keep them modular, for example when changing installation heights, adding shelves, or relocating doors. Which tools are most effective, and what are the common pitfalls to watch out for during fastening or assembly?
Perhaps you also have experience with temporarily modifying the cabinets with minimal effort, so they can be easily adapted later to a new kitchen setup?
I look forward to your tips and experiences!
plo60
26 Sep 2020 14:57
I don’t want to get overly enthusiastic here but rather offer a critical perspective.
vincent46 schrieb:
What gave me trouble was adding extra shelves afterward because the holes for the dowels are predetermined, and you can’t just drill new ones without risking stability.
That hits the mark. IKEA uses a hole grid pattern for cost reasons, which can’t be drilled repeatedly or anywhere without weakening the side panels. Excessive re-drilling quickly leads to material weakness, especially with the thin boards.
This puts a clear limit on how “quick” a modification can be, which shouldn’t be overlooked.
Also, repositioning the doors is not as simple as often claimed – the existing holes usually don’t line up with the new position, so you either need to drill new holes or end up with visible holes on the sides.
For true flexibility, the only options seem to be buying anew or choosing a completely different modular system.
I consider this an important point when it comes to genuinely flexible and fast adjustments.
Far34
26 Sep 2020 15:15
For quick remodeling:
- Use a cordless screwdriver with torque control.
- Follow the hole pattern—avoid random drilling.
- Relocate doors only on existing holes.
- Use shelf supports for adjustable shelf heights.
- Leave screws loose enough for later adjustments.
This way, you can quickly and safely customize your METOD cabinets.
Liduta
27 Sep 2020 09:22
Hello DUWAYNE and forum,
I would like to share a short guide on how to quickly modify and adapt METOD cabinets during renovations:
1. Preparation
- Plan exactly which modules need to be modified.
- Keep all screws, bolts, and fittings organized separately.
2. Disassembly
- Use a cordless drill with adjustable torque to remove fittings.
- Pay attention to the order to avoid damage.
3. Adjusting the installation height
- Use the original hole patterns for shelves to maintain stability.
- If new holes are necessary, it is recommended to pre-drill with a 3 mm (1/8 inch) drill bit to prevent splitting.
4. Repositioning the doors
- Loosen screws and attach hinges in the new position.
- If needed, fill old holes with small wooden dowels or suitable fillers.
5. Assembly
- Carefully reconnect modules, tightening connecting bolts only by hand.
- Adjust doors using the screws on the hinges.
Common mistakes and tips:
- Do not overtighten, as this can deform the wood.
- When drilling in new screw positions, pre-drill carefully.
- The fittings are sensitive to excessive force.
I hope this helps with your project!
FELOTAU
27 Sep 2020 11:40
plo60 schrieb:
This sets a limit to how "quick" a conversion can be, which should not be ignored.
I agree with that. I think it’s important that, while METOD offers a lot of flexibility, the material’s limits must be respected.
I also want to emphasize how helpful it can be to take photos of the current assembly state beforehand. This makes it easier to reassemble correctly later.
Additionally, it’s worth always having a small spare set of fittings and screws on hand—especially when working quickly, losing or damaging a screw can be frustrating.
Does anyone have experience with reliable third-party fittings or suitable alternatives for faster door reassembly?
