ᐅ Assembly of Kitchen Islands with Ample Storage and Work Surface Using the METOD System
Created on: 21 Feb 2021 14:37
liridona30
liridona30
21 Feb 2021 14:37
I am currently planning the construction of a kitchen island using the Ikea METOD system and want to create both plenty of storage space and a generous work surface. I am particularly interested in how to practically assemble kitchen islands by joining and stabilizing the individual METOD base cabinets, especially for larger islands that do not have wall support.
Do you have any tips on which connectors and fasteners are most effective? How can the countertop be securely and neatly attached to the island without causing future issues with stability or appearance?
Additionally, it would be helpful to know if the cabinet construction presents any specific challenges, for example when routing water or electrical lines, if a sink or cooktop is planned for the island.
I look forward to hearing about your experiences and recommendations, and perhaps suggestions for alternatives regarding the countertop and storage layout! Thanks in advance.
praWarre69
21 Feb 2021 16:12
Hi liridona30,
first of all, your project sounds really exciting! 😄 I have already assembled a METOD kitchen island myself and especially liked the flexibility of the cabinets. Regarding stability: it’s best to use the original METOD connector fittings, which are specifically designed to securely join the modules. You can install them quite discreetly following the instructions, so the appearance remains unaffected.
As for the countertop, I chose a thicker quartz composite slab, which is quite heavy and naturally adds stability. I attached it using the IKEA countertop clamps, which are screwed from underneath into the METOD modules. Important: don’t tighten them too much during installation to avoid stress on the slab that could cause cracking or warping later.
About connections: if you are planning to have a sink or cooktop in the island, you should allow enough space and routing for plumbing and electrical lines within the base structure early on. For example, I drilled extra openings for electrical cables and routed water pipes through support beams to prevent any pinching. This is definitely extra effort but absolutely worth it.
Don’t worry, you’ll do great! If you want, I can share some photos of my island later for inspiration 🙂
giabau
22 Feb 2021 09:43
Hello liridona30,
I would like to share some structured tips for assembling an IKEA METOD kitchen island on your own, especially regarding storage optimization and the countertop.
1. Module selection and assembly
- Choose sturdy base cabinets from the METOD range, preferably with high-quality drawer slides (e.g., Maximera or VOXTORP).
- Connect the modules using the original connector elements, as praWarre69 already mentioned. These ensure a stable connection even without wall contact.
2. Stability and fastening tips
- The stability of the island is significantly improved by a precisely fitting base frame (e.g., stable legs and cross braces).
- For the countertop, it is advisable to use the appropriate fastening clamps from IKEA to prevent pressure marks or shifting later on.
- Make sure the countertop is at least 28 mm thick (about 1.1 inches), especially on the island, since it will be under higher load.
3. Cutouts and connections
- Plan all drillings for water and electrical connections early on. Ideally, these should be located inside the base cabinets or behind the kickboards.
- Avoid drilling through load-bearing side panels after assembly, as this can reduce stability.
4. Storage design
- Use deep drawers and wide fronts in the island to maximize storage space.
- IKEA’s inner drawers or organizing systems can help efficiently utilize the available space.
Summary:
- Use original connectors and cross braces
- Secure the countertop properly, minimum thickness 28 mm (about 1.1 inches)
- Prepare connections well in advance
- Optimize storage with drawer slides
If you have specific dimensions or a plan, I’d be happy to help review it individually.
GEKAU51
23 Feb 2021 18:27
giabau schrieb:
- The stability of the island is significantly improved by a precisely fitting base frame (e.g., sturdy legs and cross braces).
I don’t fully agree with that. Especially with METOD, I often see materials being used at their limits. The particleboard-based carcasses without wall attachment can show weaknesses on larger islands, even with a base frame.
In my opinion, it is therefore mistaken to rely solely on original connectors and legs when the island is larger than about 2 meters (6.5 feet). Serious consideration should be given to additional reinforcements, possibly even custom-made metal profile constructions, to prevent sagging or wobbling.
Furthermore, a countertop that is too heavy or thick can actually worsen the problem rather than solve it. IKEA countertops are affordable but are not always designed for heavy loads. Anyone using the island as a main workspace and storage area should critically assess the combination of carcass and countertop.
For this reason, I recommend either differentiating based on island size or considering adding an alternative frame construction. Only in this way can you be sure of a durable solution.
