ᐅ IKEA Malm drawers sticking – how to adjust them properly?
Created on: 26 Feb 2024 16:23
ixeileen47
I noticed that the drawers in my IKEA Malm sideboard stick in certain spots. The issue is that the drawers sometimes catch or don’t slide smoothly when opening or closing. I have already tried cleaning the drawer slides, but that didn’t help much.
My question is: How can these drawers be better adjusted to ensure smooth opening and closing? Are there adjustment screws or specific methods to optimize the drawer’s alignment or the gap between the drawer and the side panels?
I would appreciate concrete tips tailored to Malm furniture, as I often read that this problem is addressed differently in other models.
Thanks in advance!
Lorukeo
27 Feb 2024 12:43
The following additional notes from a craftsmanship perspective:
- When adjusting, make sure the drawer does not press too far inward, as this can cause long-term wear of the plastic profiles.
- It is advisable to additionally check the horizontal level of the sideboard itself, as slight tilting of the entire furniture can affect smooth operation.
- For a permanent solution, in individual cases, it is possible to use alternative sliding rails with extra stoppers; however, these are not included from the factory.
peovin
27 Feb 2024 13:02
Important: Always work carefully. Dust and crumbs in the tracks are often the cause, not the adjustment itself.
Josefane
27 Feb 2024 15:20
Elias schrieb:
I have also made a habit of not overloading the drawers
An interesting observation. This raises the question of whether the jamming is primarily due to static load or mechanical misalignment.
I also wonder if the design of the Malm drawers is sufficiently robust for long-term use, or if the jamming is more a sign of wear on the drawer slides. Are there any reliable experience reports on this?
Maria35
27 Feb 2024 16:45
Josefane schrieb:
whether the jamming is primarily caused by static load or mechanical misalignment
Both can be true depending on the case. The plastic running rails are quite durable, but with overloading and incorrect adjustment, the likelihood of changes in geometry increases.
My advice: focus on precise adjustment and moderate load to avoid actual wear. In professional settings, high-quality metal telescopic slides are often used, which are more durable.
RENMA
28 Feb 2024 09:10
Regarding fine adjustment, I recommend a controlled approach:
1. Completely remove the drawer.
2. Check the drawer slides for secure attachment.
3. Insert the drawer into the slides and check for any squeaking or sticking.
4. Slightly raise or lower the slides, usually at the rear of the track.
Adjustment at the front part has less impact, as it usually only limits the drawer’s extension.
This way, you can gradually narrow down any misalignments.
ixeileen47
28 Feb 2024 10:33
Thank you all for your detailed and practical responses!
I will remove the sliding rails this evening and then systematically realign them following your tips. I found JORDON’s suggestion to slightly raise the rear end of the rails especially interesting – I will definitely try that.
I will also make sure not to overload the drawers to reduce the strain.
If I come across any questions or problems, I will gladly return here.
