ᐅ How can I readjust Malm drawers?
Created on: 1 Jun 2021 08:17
NON68
Hello everyone, I recently purchased an IKEA Malm drawer chest and noticed that the drawers don’t adjust quite properly. Specifically, some drawers are difficult to open and close, while others are slightly misaligned in the tracks, making closing them harder. I want to adjust the drawers so they operate smoothly, evenly, and without issues. Does anyone have experience with the mechanical adjustment of these Malm drawers? Is there a specific technique or trick to correctly calibrate the drawer slides or the drawers themselves? I would appreciate a detailed guide or tips, ideally with advice on aligning the drawers and ensuring smooth operation.
nojaus
1 Jun 2021 16:11
NON68 schrieb:
Do you have to pull the drawer completely out of the cabinet for this, or even disassemble it?
I can confirm that usually pulling it out completely is enough. Sometimes the fastenings of the drawer slides are very tight, but under no circumstances should you use force. If you’re unsure, it’s better to take a bit more time and carefully feel the plastic parts with a steady hand. Note: In some older models, the drawer can be removed by slightly lifting it and then pulling it forward from the back, so check the manual.
FEKAU
2 Jun 2021 08:26
When adjusting Malm drawers, it is important to distinguish between horizontal and vertical adjustments. Most models allow at least horizontal shifting by adjusting the plastic components in the drawer slides, while vertical adjustment is often possible by repositioning the screws on the cabinet frame. Therefore, separate the process: first check and adjust the drawer slides, then align the drawer front once the cabinet frame is installed. Slight modifications of the screw holes may be necessary if a precise fit seems unattainable. In any case, avoid using force; instead, apply a systematic approach of opening, adjusting, and testing.
SUBEN60
2 Jun 2021 09:13
FEKAU schrieb:
It is important to distinguish between horizontal and vertical adjustment.
That hits the nail on the head. Additionally, I recommend checking the drawer slides for any damage when adjusting Malm drawers. Bent or broken metal parts prevent proper alignment and must be replaced before adjustment. It is also advisable to lubricate the metal guides with a suitable, dry lubricant (for example, silicone spray) to ensure smooth movement.
sonplo
2 Jun 2021 10:47
Exactly. If there is mechanical damage, even the best adjustment won’t help. In that case, replacement parts, which can be ordered directly from IKEA, are recommended. This saves time and hassle.
NON68
2 Jun 2021 12:34
I have now removed all the drawers and thoroughly cleaned the slides. During this process, I noticed a few of these plastic clips and was able to slightly adjust them with gentle pressure. After that, one of the problematic drawers ran much more smoothly. A few questions: 1) Should these clips be fixed permanently in their new position, for example by screwing them in place? 2) Is there a risk that the settings will change again over time? 3) Some of my drawers creak a little—would lubricating them help, or not?
Matthewt48
2 Jun 2021 13:02
NON68 schrieb:
1) Should these clips be permanently fixed in their new position, for example screwed in place?
The plastic clips themselves are usually designed to clip or slide into predefined grooves; permanent screwing is generally neither intended nor necessary. It is important that they are properly engaged so they do not slip.
There is a slight risk, especially under heavy use or frequent adjustment. Therefore, it is advisable to check regularly and readjust if needed.
NON68 schrieb:
3) Some of my drawers creak a bit; would lubricating help or not?
Yes, using a dry lubricant such as silicone spray or a special furniture oil can help. Oil-based lubricants tend to attract dust, so silicone is generally preferred.
