ᐅ Why do MALM drawers stick even when installed correctly?
Created on: 30 May 2023 18:12
danmin41
Hello everyone, I noticed that the drawers in my Malm dresser project keep sticking despite seemingly correct assembly. The drawer slides are properly installed, all screws are tight, yet the drawers don’t open and close smoothly – they often catch, and you have to use quite a bit of force. This puzzles me because I followed the instructions exactly, all the drill holes are correctly spaced, and the front is aligned straight. Does anyone have an idea what else could be causing this? Is there a common issue with Malm drawers that is easily overlooked, or any specific tips on how to permanently eliminate the grinding or sticking? I look forward to your experiences and suggestions.
tra_nina
31 May 2023 09:45
A precise adjustment of the front panel is essential. The Malm drawers are equipped with clamps that allow adjustment in horizontal, vertical, and depth directions. This often involves turning small screws on the back of the front panel. This frequently resolves sticking issues, as the front then fits against the carcass wood without pressure. Additionally, the front should not be misaligned, as this can block the sliding rail mechanism. My advice: take a quiet moment, gently loosen the front panel, carefully adjust bit by bit, and test the drawer in between.
farGlen
31 May 2023 10:12
In addition to front adjustment, lubricating the guide rails can be helpful. IKEA recommends light silicone spray or graphite powder. Regular oil is not ideal, as it attracts dirt. Small components such as rollers or ball cages should move freely.
reni45
31 May 2023 11:40
Also check if the drawer runs completely flush within the guide track. If it hits the back of the dresser, it often gets stuck. Sometimes it helps to lift the drawer slightly or gently shift it left or right.
gadalu
1 Jun 2023 13:26
Additionally, I would like to point out that the strain caused by overfilled drawers as a reason for sticking is often underestimated. Since MALM systems have standardized tolerances, uneven loading (e.g., heavy items placed at the front) increases friction. The solution is to distribute the load as evenly as possible and avoid placing heavy items only in one corner.
Deandre schrieb:
"Tip: Fully extend the drawer and test with gentle force to see if it sticks anywhere."
This method should also be carried out with some care to avoid damaging the drawer.
todunar
2 Jun 2023 16:02
Hey! The tips here are really great, I'm really happy about that! 🙂 I had the same problem, and what helped me a lot was adjusting the front a bit more precisely and lubricating the sliding rails with silicone spray. Since then, they glide like butter! 🙂 So don't get discouraged, it's worth being patient – the result is amazing.
