Hello everyone, my IKEA Malm bed has recently started squeaking with almost every movement, and it’s really annoying. I have already checked that all the screws are properly tightened, which they seem to be. The noise probably comes from the joints between the slatted frame and the bed frame, but I want to avoid taking the bed completely apart. Does anyone know quick and effective repair tips to stop the squeaking fast? It would be great if the solution can be done with minimal effort since I use the bed every day.
Leonardteo13 Mar 2020 12:47Squeaking in Malm beds often occurs due to minimal friction between wooden parts, especially when the wood fibers change because of humidity. Besides tightening the screws, I recommend using very fine sandpaper to gently roughen or smooth any rough spots on the contact surfaces. Afterwards, treat the surfaces with furniture wax or beeswax, which significantly reduces friction.
BLAMAU schrieb:
Try completely loosening the screws again and then treat the joints with a light lubricant like WD-40. Thanks for the tip! I have WD-40 at home, but I wonder if it’s suitable for wood? Could it cause permanent stains or other damage?
Leonardteo schrieb:
Use very fine sandpaper to slightly roughen or smooth rough spots on the contact surfaces That sounds reasonable, but I’m a bit concerned about working visibly on the frame. How discreet is it really?
I’m open to simple but effective tips that I can apply without leaving noticeable marks.
Hey, squeaking beds can be really annoying, but they’re usually easy to fix 😄! I tried using candle wax—just rub a little on the contact points; it doesn’t shine, smells nice, and acts like a small protective layer. I’d recommend using WD-40 more for metal screws and steel connectors, not on wood, as it could discolor the surface.
The important thing is to tighten everything properly after treatment—that makes a big difference! Good luck and keep your spirits up, it will get better 😉!
rekijan schrieb:
I tried using candle wax – rubbing a bit on the contact points Candle wax is a classic solution. But honestly: who wants to voluntarily rub wax on their bed? Ikea beds are mostly designed for affordable, functional use, which naturally suffers when you start tinkering. For me, squeaking often comes down to too much DIY – either tighten the fittings or accept it.
Sometimes there simply isn’t a quick fix except replacing parts. Maybe the squeaking is even a sign of quality? 🙂
