ᐅ IKEA Malm bed creaks in hot summer weather – any suggestions for a solution?
Created on: 24 Apr 2021 09:17
Haykto
I have an IKEA Malm bed, manufactured in 2018, and recently it has started to annoy me because it squeaks loudly when I move, especially during hot summer weather. It is the model with drawers underneath, but the noise occurs regardless of the drawers, so it’s likely mechanical or caused by material expansion. I have already checked if any screws are loose – everything is tightened. The squeaking seems to be related to the heat or rather the humidity in the room. Does anyone have experience or specific solutions on how to permanently stop the Malm bed from squeaking in high temperatures? Are there any special maintenance products or mechanical adjustments that might help? A simple solution that prevents this annoying noise would be great.
pauPierce26 Apr 2021 09:34Katan schrieb:
Maybe you already have a window that you open early in the morning and close in the evening?It is also important to maintain a consistent room temperature. When heat varies significantly over several hours or days, wood-based materials tend to react noticeably. Therefore, it is advisable to consider air conditioning or at least ventilation in the bedroom, if structurally possible.
I would also recommend adjusting the stresses in the frame using small adjustment screws. Proceed carefully to avoid causing overstretching.
cassandra schrieb:
Use only very fine sandpaper, e.g., grit 220, to avoid damage.That’s an excellent tip. Indeed, a slightly roughened surface helps lubricants adhere better. For anyone who wants to try this: be sure to wipe clean thoroughly after sanding, otherwise dust can build up between the panels and increase squeaking.
One last note: when retightening screws, ideally use a torque wrench or at least have a good feel for the resistance. Over-tightening can also damage the panel.
