ᐅ The IKEA Malm bed keeps squeaking – any permanent solutions?
Created on: 21 Jan 2023 09:17
napiet69
I have an IKEA Malm bed (180cm x 200cm (71 inches x 79 inches)) that has been squeaking on and off for quite some time. It especially happens when turning over or sitting down, which is pretty annoying. I’ve already taken the bed apart and reassembled it several times, checked and tightened all the screws, but the squeaking persists.
I suspect the issue might be with the wooden joints or the slatted frame, maybe also the frame supports. Has anyone found a permanent solution to completely eliminate the squeaking? I would like to know if the problem can be fixed long-term with additional aids (such as felt pads, lubricants) or if specific parts need to be replaced.
Thanks for your help!
NOAHSAU
22 Jan 2023 09:50
To be honest: For the price IKEA charges, I actually expect a bed like this not to squeak.
Charles schrieb:
For Malm beds, it can help to rub flat joints with some wax or paraffin
This raises the question of whether the problem lies in the material and build quality, and if the customer should really have to cover such issues themselves. Sure, delicate materials are often prone to this, but the annoying squeaking shouldn’t be included in the price.
BAUEVA
22 Jan 2023 11:16
NOAHSAU schrieb:
whether the material and workmanship quality is the issue here
That’s a valid point. IKEA furniture is designed for cost-effective production.
All the more important to take simple repair steps yourself.
In addition to felt pads and wax, I have also had good results with thin rubber caps on screws to completely eliminate slight movements in my furniture.
Devin
22 Jan 2023 13:22
My quick recommendation:
Completely loosen the screws, rub all frame parts with furniture wax or paraffin, then cleanly and securely reassemble.
Additionally, glue felt pads at contact points.
This will most likely eliminate the squeaking permanently 🙂
