ᐅ Ikea Faktum Upper Cabinets / Installation
Created on: 3 Feb 2011 03:53
mediendoc
mediendoc
3 Feb 2011 03:53
I need advice from you regarding the wall mounting of Faktum wall cabinets.
The special feature is that the tile backsplash has a thickness of 2cm (1 inch); new tiles were installed over the old ones.
What screw thickness, length, and suitable anchors should I use?
mediendoc
Maverick1854
3 Feb 2011 06:48
What type of wall do you have?
mediendoc
3 Feb 2011 07:37
Hi Mav
A standard brick wall
Maverick1854
3 Feb 2011 07:48
Then screws measuring 8 x 60mm (8 x 2.4 inches) or 6 x 60mm (6 x 2.4 inches) with appropriate wall plugs should be sufficient.
If you want to be absolutely sure, use 8 or 6 x 70mm (8 or 6 x 2.8 inches).
Unless you plan to attach a truck. In that case, I would not recommend screws but a heavy-duty crane.
mediendoc
3 Feb 2011 07:52
ok, thanks for your quick response
best regards mediendoc
