ᐅ Ikea blank handle on the sink cabinet conflicts with the front rail
Created on: 20 Nov 2012 21:14
cinimini
cinimini
20 Nov 2012 21:14
I purchased the kitchen sink cabinet with drawers (item number: 598.688.19) and plan to install it using the slab handles, meaning both on the top and on the middle piece between the fronts. The problem is that the connecting rails (117786 and 117785) of the drawer fronts would rest on the slab handle, since there is only one drawer, but visually it looks like two, which are only connected by the rails.
My question is whether anyone has already installed a slab handle on the middle piece between the fronts without any issues, or if washers need to be placed under the screws to relieve tension on the rail and compensate for the height of the slab handle? Do the fronts end up misaligned due to the slab handle height? And is the rail visible from the front above the slab handle?
Thank you in advance for your help!
Lara
Nayla_1068
21 Nov 2012 17:43
Hi,
The drywall bead looks so narrow visually, just leave it out at that spot. It won’t be noticeable anyway, and as you’ve already noticed, it doesn’t serve any function.
Otherwise, definitely use washers under the screws. Over time, the facade will probably warp if it remains under such tension.
NFU
Cheers.
IKEA-Experte
22 Nov 2012 00:10
The connecting rails have a spacing notch that creates a joint with the correct gap. If a wide strip is added in between, the gap becomes too large. This looks awkward, and with a strip on top, the drawer cannot be closed properly.
cinimini
23 Nov 2012 16:25
So, I have simply installed it now. A few washers were necessary; the gap caused by the rail and the handle is not noticeably visible from the front, and the drawer opens and closes smoothly.
Thanks for the tips!
