ᐅ Using Ikea Besta Units in the Kitchen – What Is the Best Way to Fit Them?
Created on: 8 Mar 2022 17:23
Pudukeo
Pudukeo
8 Mar 2022 17:23
Hello everyone, I am currently planning my kitchen layout and considering using the Ikea Besta system for it. My question is: What is the best way to use Ikea Besta in the kitchen so that it is both functional and visually appealing? I am particularly interested in how to combine the different modules effectively, what customizations are possible, and how it integrates with typical kitchen appliances and countertops. Are there any tips to keep in mind during installation, for example regarding load capacity, storage optimization, and making the best use of depth? I would appreciate any experiences and recommendations that could help me use the Besta system as an alternative kitchen solution in a truly effective way.
Meoru
8 Mar 2022 17:57
The Besta system works well for open kitchen areas if you want to use it as a flexible storage solution. Keep in mind that the shelves have a limited load capacity, so it's better to store heavy appliances on the lower shelves. For better integration, suitable doors and fronts are helpful.
RETRAVIS
8 Mar 2022 19:11
Basically, Ikea Besta offers a modular system that can be adjusted with variable dimensions to fit kitchen spaces flexibly. For kitchen use, the maximum load per shelf is usually 25 kg (55 lbs), which is suitable for light to medium-weight kitchen items but does not replace full base cabinets. It is recommended to pair the system with suitable countertops (e.g., wood or laminate options) for added stability and improved appearance. Before planning, it is important to clarify the room dimensions and intended use to select appropriate cabinet depths (e.g., 40 cm (16 inches) or 60 cm (24 inches)). Built-in appliances are not designed for Besta modules, so these systems are better suited as additional storage, dish cabinets, or open shelving units.
O
olivernu
9 Mar 2022 08:47
RETRAVIS schrieb:
For use in the kitchen, the maximum load per shelf is usually 25 kg (55 lbs), which is suitable for light to medium-weight kitchen items but does not replace full kitchen base cabinets.
This is a very important point. It should be remembered that Besta units often do not offer the same stability or rail quality as full kitchen cabinets. However, they are well suited for storing food supplies, dishes, or cookbooks. Additional reinforcement is necessary for work surfaces. I also recommend adjusting the dimensions and shelf depth to fit your appliances and storage needs. Functionality can be improved with the help of pull-out drawers and organizer inserts.
baAlejandr
9 Mar 2022 10:35
Anyone planning to use the Besta system in the kitchen should definitely consider integrating a sturdy countertop, ideally with a thickness of at least 2.8 cm (1.1 inches). This significantly increases load-bearing capacity. Additionally, wall fixings are essential to eliminate the risk of tipping. For more design flexibility, Ikea offers various front options, and by adding kickboards or covers, the overall appearance can be made more professional. For practical use, it is also recommended to customize the interior layout with system accessories, such as cutlery trays and boxes.
Pudukeo
9 Mar 2022 14:51
baAlejandr schrieb:
If you want to use the Besta system in the kitchen, you should definitely plan for the integration of a sturdy countertop, preferably with a thickness of at least 2.8 cm (1.1 inches).
Thanks, that’s a helpful tip! I’m also curious how you handle the backsplash: Do many of you use the standard backsplashes from Ikea, or are flexible solutions like custom-fitted backsplashes more practical? And how did you secure the modules to the countertop to ensure everything stays stable? I’d rather avoid having to fix things after everything is installed.
