wilcogo444 Feb 2023 09:23Hello everyone,
I recently assembled several Besta cabinets from Ikea, but ran into an unpleasant situation: one of the screws broke off while being tightened and is now stuck completely inside the wood. My question is: what is the best way to deal with broken screws in Ikea Besta furniture?
Specifically, I am interested in methods to safely remove or replace these screws with minimal damage. I want to avoid compromising the stability or appearance of the cabinet. Are there any special tools suitable for the relatively thin screws and the material used?
I would also appreciate any advice on how to prevent such situations during assembly, if anyone has experience with this.
Thanks in advance for your tips!
Hello wilcogo44,
I understand your problem well; this happens quite often, especially with furniture that has thin, delicate screws like those in Ikea Besta.
Here are a few suggestions on how to proceed:
- If the screw is only partly sticking out, try carefully pulling it out with needle-nose pliers or a small screwdriver.
- For completely broken screws, a special screw extractor can help. These are small tool kits designed to grip and remove broken screws.
- Sometimes it also helps to gently loosen the material around the screw with a fine drill so the screw can be removed more easily.
- Be careful when drilling: do not go too deep to avoid damaging the particleboard material.
- If nothing works, you can conceal the remaining screw with wood filler and insert a new screw slightly offset from the original position.
To prevent this, I recommend screwing in straight without applying too much force and using suitable cordless screwdrivers with torque control.
I hope these tips help you!
Interesting post, wilcogo44. I think the issue of broken screws in Ikea furniture should also be considered in the context of manufacturing quality and materials.
That sounds pragmatic, but it risks negatively affecting the load-bearing capacity of the particleboard. Who can guarantee that the furniture will still have the same stability afterward?
I generally recommend checking first whether Ikea’s spare parts program can help in such cases or if it’s better to file a formal complaint. Simply drilling into the wood could cause more harm than good in the long term.
What are your experiences with this?
Jeanbar schrieb:
Sometimes it helps to slightly loosen the material around the screw with a fine drill so the screw comes out more easily.
I agree with some of Hector’s points, but with Ikea furniture, the materials are generally designed to be repairable.
For broken screws in Besta units, I recommend:
- First, clean the hole if needed using a small drill bit.
- Then insert a screw of the same diameter into a slightly offset hole.
- To reinforce the potentially weaker area, you can use wooden dowels or wood glue.
If done carefully, the repair usually does not affect the functionality.
And of course, a good cordless drill with torque control greatly reduces the risk of broken screws.
Hello wilcogo44,
here is a brief guide for dealing with broken screws in the Ikea Besta system:
1. Check the position: Is the screw still partially embedded in the wood? If so, first try to grip it with tweezers or pliers.
2. Screw extractor: If the screw is completely broken off and stuck in the wood, get a special screw extractor. Be careful: fine wires on the extractor are essential, especially with thin screws.
3. Drill carefully: If necessary, drill into the center of the screw with a thin metal drill bit to create a small starting point for the extractor.
4. Insert a replacement screw: Once the screw is removed or partially protruding, you can insert a new screw slightly offset to maintain stability.
5. Check stability: After replacing, inspect the furniture assembly for any weak points.
Mistakes to avoid:
- Applying too much force when trying to remove the screw.
- Using a drill bit that is too large.
- Trying to insert the replacement screw in exactly the same spot (particle board may split).
Good luck with the repair!
Mistakes to avoid:
