ᐅ IKEA Besta – How do I replace the rollers on the drawers?
Created on: 19 Dec 2016 09:18
Janfu
Janfu
19 Dec 2016 09:18
Hello everyone, I recently got an IKEA Besta shelving unit with drawers, and now the drawer roller wheels are starting to stick and squeak. My question is: How exactly do you replace the roller wheels on Besta drawers? I am especially interested in a step-by-step guide, including which tools are needed and what to watch out for to ensure the drawers run smoothly again afterward. Are there any special tips for older models or different versions that I should be aware of? Thank you in advance for your help!
taotis53
19 Dec 2016 10:47
In general, replacing the rollers on IKEA Besta drawers is quite manageable and requires only a few steps. First, fully pull out the drawer and ideally place it on a flat work surface. The rollers are attached to the sides of the drawer bottom and are usually secured either with clips or small screws. The tools needed are typically a Phillips screwdriver and, if necessary, a small flathead screwdriver to release the clips.
It is important to carefully observe how the old rollers are attached during removal, as there are different variants depending on the year of manufacture and model. The new rollers should be installed in the same position, ensuring they snap in properly or are securely screwed in. After that, test the smoothness of the operation and make minor adjustments if needed.
Another tip: Check whether the drawer bottom is warped, as this can affect functionality. Generally, always use original replacement parts to ensure proper fit and load capacity.
EDWARD0
19 Dec 2016 11:13
Pull out the drawer, loosen the rollers with a screwdriver, remove the old rollers, install the new rollers, tighten the screws, insert the drawer, check the function.
harold
19 Dec 2016 13:22
I am happy to provide a more detailed guide on how to replace the rollers of IKEA Besta drawers:
- Step 1: Fully pull out the drawer and place it securely on a work surface to avoid injury.
- Step 2: Check how the rollers are attached: either with screws or plastic clips.
- Step 3: If screws are used, carefully remove them with a suitable Phillips screwdriver.
- Step 4: If clips are used, gently pry them off with a small flathead screwdriver or flat tool to avoid damaging the roller.
- Step 5: Completely remove the old roller.
- Step 6: Fit the new roller precisely in place and either snap it in or secure it with screws.
- Step 7: After installation, carefully slide the drawer back in and open and close it several times to ensure smooth operation.
A common mistake is installing the rollers at an angle or not snapping them fully into place, which can cause uneven movement. It is also advisable to check the drawer slides (rails) for any damage.
Janfu
20 Dec 2016 08:37
Thanks for the quick responses!
taotis53 schrieb:
It is important to carefully observe how the attachment works when removing the old rollers, as there are different versions depending on the year of manufacture and model.
Are there any known standard types of rollers for Besta drawers? Mine are about 3 years old, and I suspect they use a clip-on attachment. Is it possible to buy the rollers individually from IKEA, or is it better to get a full set for the entire storage system? I want to plan as precisely as possible to avoid ordering twice, thanks!
flojo
20 Dec 2016 09:02
Janfu schrieb:
Are there any standard versions of the roller wheels for Besta drawers? Mine are about 3 years old, and I suspect they are models with a click fastening.
For the common Besta drawer models from recent years, there are indeed mainly two versions: roller wheels with screw fastening and those with a plastic clip (click system). The click fastening type is quite common, especially in newer models.
Janfu schrieb:
Is it possible to buy the wheels individually from IKEA, or is it better to get a full set of wheels for the entire storage system?
IKEA usually offers replacement wheels only in sets; individual wheels are rarely available. So, if you have several drawers, it’s generally better to buy a complete set. This avoids unnecessary delays and ensures you get matching parts in original quality. Also, having all wheels uniform helps with smooth operation.
