ᐅ IKEA BESTA DIY: How to build a combination with open shelves?
Created on: 21 Dec 2023 17:24
ELHENNING
ELHENNING
21 Dec 2023 17:24
Hello everyone, I am planning to build an IKEA Besta combination with open shelving and would appreciate tips and experiences. Specifically, I want to know how to best combine the modules to create an aesthetically pleasing and stable unit that is also open enough to showcase decorative items, books, and electronic devices effectively. I am considering mixing individual open shelves with closed compartments. Are there any recommendations regarding the choice of specific BESTA components, assembly, or any tricks to increase storage space without losing the openness? Additionally, I am interested in whether special back panels are needed for open shelves, and if so, which options are advisable. Looking forward to your suggestions and solutions!
peovin
21 Dec 2023 18:15
For open shelves, the BESTA frames without doors are suitable. Make sure to stack at least two or three units on top of each other for greater stability and always secure them to the wall with brackets. You can omit back panels if the wall itself is already stable and visually appealing.
Domau0
22 Dec 2023 09:37
Basically, when combining open and closed BESTA modules, it is important to first develop a clear idea of the layout. I recommend working with a grid: the standard BESTA elements come in two heights (38 cm (15 inches) and 64 cm (25 inches)) and three widths (40, 60, 120 cm (16, 24, 47 inches)). You can create open shelves by simply omitting the door module and using the carcass only. For a stable construction, you should:
- Align the modules on a level surface and securely anchor them to the wall (use angle brackets or special mounting kits available from IKEA).
- Either leave out the back panels completely if the wall is very even, or cut thin MDF boards for back panels, which you can even paint for contrast.
- Make sure not to place overly heavy items on open shelves alone, as they may sag forward without support.
Also: Create a drawing or sketch beforehand, preferably to scale, and check whether all devices and objects you want to include will actually fit. For example, open shelves are practical for electronic equipment with cables because they allow better cable management. Do you already have an approximate room size or specific dimensions for the combination you are planning?
Lucien
22 Dec 2023 14:51
To precisely address the topic of stability in BESTA combinations with open shelves: it is essential not to overlook wall mounting with these types of constructions. The open modules have no doors, which reduces the frame stability. I recommend:
- Using angle brackets at the top and bottom to prevent sagging.
- For larger modules (width 120 cm [47 inches]), adding an extra center support or legs.
- Back panels made of thin wood or fiberboard can provide stabilization, as long as a fully open look is not required.
Where back panels are used, painting or wallpapering can create a design that lightens the overall appearance. Additionally, magnetic catches are advisable for semi-enclosed elements to avoid rattling doors.
bauku
23 Dec 2023 11:03
So great that you’re taking on an IKEA BESTA project with open shelving! 🙂 The combination of open and closed sections is very flexible and looks fantastic. Regarding the back panels: I used simple thin plywood sheets for my setup and painted them myself – it adds a lot of charm! I also installed LED strip lights in the open compartments, which create really nice effects in the evening.
One more tip: If you’re open to experimenting, try combining tall and wide cabinets to achieve an asymmetrical look – it feels lively and modern. Don’t hesitate to fix the units to the wall following IKEA’s recommendations – it ensures safety and makes the whole setup very sturdy.
Looking forward to seeing any progress you share!
