Hello everyone, I plan to modify one of my IKEA Billy shelves by adding a side table to make better use of the available space. However, I am not entirely sure how the modification process works. Specifically, I would like to know: How do you remove the shelves from the side panels, and do I need any special tools to safely install or remove the side table without causing any damage? Is there a standard procedure or perhaps a "trick" that I should be aware of? Additionally, I am interested in whether the back panel of the shelf needs to be removed for the modification or if the side table element can be detached separately. Any tips are greatly appreciated!
flo-Theres21 Sep 2023 08:55As an addition: When dismantling the side table, be careful not to damage the fasteners, especially the metal anchors and, if applicable, the tabs used for stabilization.
Even if the back panel does not need to be removed, detaching it can help relieve tension on the shelving unit and significantly improve handling. Carefully documenting the order of disassembly (e.g., which screws go where) is recommended to make reassembly easier later.
If the shelving unit is older, please check the condition of the joints before disassembly, as older Billy shelves sometimes have weaker glued areas. Rough handling can quickly compromise the stability.
