Hello everyone, I recently assembled some IKEA Platsa shelves and was wondering: how secure are the screw connections in IKEA Platsa in terms of stability and durability?
I noticed that the screws in one of the units seem quite small, even though the furniture appears fairly sturdy. Since these shelving systems are often expanded modularly and sometimes moved around, I’m interested to know if the screw connections will actually hold up over time or if it’s better to expect some rework or reinforcement.
Does anyone have good knowledge of the construction and quality of the connecting parts? Are there any experiences or recommendations on how to ensure the screw connections remain secure in everyday use without requiring too much extra effort?
dijan schrieb:
If you want it even more secure, a bit of thread locker helpsThanks for the tip! What type of thread locker would you specifically recommend for furniture joints like these? I don’t want to use anything that makes the screws impossible to remove later, as I plan to expand the modules modularly.
Joshbe schrieb:
Alternatively, thread lockers can be consideredAre there any proven products or brands? And what else should one pay attention to when retightening or carefully handling the connecting parts?
Framar schrieb:
Which type of threadlocker is specifically recommended for such furniture connections?Medium-strength nylon-based threadlockers (e.g., medium-strength threadlocker) are recommended. They prevent unintentional loosening but can be removed later with tools if necessary.
Important:
- Use only a small amount to avoid the need for excessive force during disassembly.
- Avoid high-strength products, as these are often difficult or impossible to remove.
When retightening: Always tighten by hand only. Over-tightening can damage the threads and weaken the connection.
Framar schrieb:
I don’t want to use anything that will make the screws impossible to remove laterThen go ahead and use medium-strength threadlocker. It keeps everything tight without loosening, but it can be removed if you’re careful.
Tip: Less is more – too much threadlocker can actually cause problems. Just a tiny drop on the threads is enough.
