Hello everyone, I recently assembled some IKEA Platsa shelves and was wondering: how secure are the screw connections in IKEA Platsa in terms of stability and durability?
I noticed that the screws in one of the units seem quite small, even though the furniture appears fairly sturdy. Since these shelving systems are often expanded modularly and sometimes moved around, I’m interested to know if the screw connections will actually hold up over time or if it’s better to expect some rework or reinforcement.
Does anyone have good knowledge of the construction and quality of the connecting parts? Are there any experiences or recommendations on how to ensure the screw connections remain secure in everyday use without requiring too much extra effort?
The screw connections in IKEA PLATSA are fundamentally designed for their intended use. The connectors and screws used are standardly rated for moderate loads and regular use.
The screws are not oversized, as the design prioritizes modularity and easy assembly. Stability largely depends on proper installation: tightening the screws carefully without over-tightening is important.
For increased loads or frequent modifications, it is recommended to periodically check the screw connections and re-tighten them if necessary. Alternatively, thread-locking compounds can be considered to prevent loosening.
Joshbe schrieb:
The screw connections in IKEA PLATSA are fundamentally designed for their intended use.Exactly, I can confirm that. The construction is standardized and generally works well as long as the assembly instructions are followed precisely.
In the PLATSA series, the screws are not particularly thick, but the materials and connection method (metal dowels plus screws) provide sufficient stability.
Important: During assembly, all screws should be tightened evenly. Uneven tightening can weaken the connection.
Hey, just to keep it casual: The screws aren’t huge heavy-duty bolts, but they’re totally fine for a living room shelf. 😊
If you want to make it even more secure, use a bit of threadlocker so nothing wobbles if someone bumps into it or kids are playing around.
So – no need to worry, but it’s always a good idea to occasionally check that all screws are still tight.
flo-Theres24 Mar 2024 07:26Regarding the durability and safety of the PLATSA screw connections, IKEA provides a standard quality with this system that is designed for everyday use in residential settings.
The connectors are made of metal and offer good stability, and the back panels help to further reinforce the structure.
It is crucial to work carefully with the supplied tools during assembly. Tightening securely, but without over-tightening, ensures the best possible strength.
Regular retightening is recommended anyway, as wood joints can shift slightly due to load and changes in climate.
