ᐅ How much strain do Ikea PAX drawers typically endure with frequent use?
Created on: 6 Jul 2021 08:17
CHENEL69Hello everyone,
I am considering installing the IKEA PAX system with the matching drawers at my home. My specific question is: How much wear and tear do the IKEA PAX drawers actually experience with frequent use, especially when they are opened and closed several times a day?
I am particularly interested in long-term use and how durable the drawers and their sliding mechanisms are when storing heavier clothing, documents, or kitchen utensils, for example. Are there any experiences regarding wear, stability, or potential technical issues such as jamming or deformation?
I would appreciate any feedback, especially if you have tested specific loads or can share your usage experiences. Thanks in advance!
CHENEL69 schrieb:
How much strain do IKEA PAX drawers actually endure with frequent use, especially when opened and closed several times daily?I completely understand how important durability is to you. In my experience, the PAX drawers are very sturdy with normal use. I open my drawers at least 5 times a day, mostly with clothes inside, and after almost 3 years they still operate very smoothly.
Of course, you shouldn’t constantly load them with heavy weights. I once had heavy bags in them for a short time, and you could notice slight wear on the runners. But overall, I find the materials quite durable.
Sometimes people report jamming – but that was usually due to incorrectly adjusted drawers or debris in the runners. If you check and clean them regularly, they tend to last quite a long time.
I hope this helps a bit!
nojaus schrieb:
If you check regularly and keep them clean, they last relatively long.Exactly! I would like to explain in more detail how to ensure the load capacity and durability of IKEA PAX drawers, especially with frequent use.
1. Observe the load limit: The maximum specified load is usually around 15 kg (33 lbs) per drawer. It is advisable not to exceed this permanently.
2. Assembly quality: Make sure to assemble the drawers precisely and install the drawer slides properly. Poor assembly can significantly reduce load capacity.
3. Regular maintenance: The slides do not require special lubricants, but cleaning off dust and debris is essential. Contaminants increase friction and restrict smooth operation.
4. Avoid overloading: Especially with heavy or unevenly distributed loads, the drawer can deform or jam.
Conclusion: PAX drawers are designed for frequent, long-term use if the above points are followed. Problems often occur due to incorrect assembly or overloading.
I hope this provides a bit more clarity.
kemads46 schrieb:
The PAX drawers are designed for heavy, long-term use if the above points are followed.I would like to put that into some perspective. Basically, the technical specifications from IKEA are accurate, but in my experience, they are often intended only for short- to medium-term use.
When we analyze frequent use more closely, the following critical aspects become apparent:
- Material fatigue: The drawer fronts and especially the side panels made of thin MDF or particleboard can warp or develop small cracks over time.
- Load dynamics: Constant opening and closing acts as cyclic loading, which can gradually loosen the connections in the long run.
- Sliding elements: The basic plastic or metal runners are sturdy but show signs of wear after a few years, especially if the drawer is overloaded.
An important point is that “frequent use” varies greatly. With daily multiple openings of 10-15 times, you can expect the first signs of damage after about 4-5 years. It is also recommended to occasionally tighten the screws and detect any deformations early.
In conclusion, you should not blindly rely on the manufacturer’s specifications but instead focus on regular inspections to extend the service life.
