ᐅ How important is the installation of the wall mounting for the Ikea BRIMNES?
Created on: 10 Nov 2023 18:23
ren45
ren45
10 Nov 2023 18:23
I recently purchased an Ikea Brimnes furniture piece (a wall shelf and cabinet combination) and I’m wondering how important it really is to install the wall mounting for this model.
My main question is whether it is absolutely necessary or required for safety reasons to secure all brackets and screws to the wall, or if it’s possible to set up the furniture without wall mounting without a significant risk of tipping or falling over.
I’ve read that Ikea always recommends wall mounting, but it would be helpful if someone with experience could share whether it is truly mandatory, especially for normal use in an apartment.
Thanks in advance! What risks or hazards might occur in either case? Do you need special tools or fixing materials for certain wall types? Are there any tips on how to properly install the mounting or what to watch out for?
Looking forward to your advice and tips!
Matthewt48
10 Nov 2023 19:07
Hello ren45,
Regarding your question about the importance of wall mounting for Ikea BRIMNES, I can share some experience. In general, wall mounting is very important for almost all tall and relatively narrow furniture like BRIMNES because it secures them against tipping over.
It is true that Ikea explicitly recommends wall mounting. The reason is that these pieces of furniture are often quite tall, which poses a significant tipping hazard, especially if there are children in the household or if the furniture is loaded, for example by opening doors, leaning on it, or sitting on it.
Not having the furniture secured to the wall can therefore be dangerous – furniture can fall over, causing serious injuries.
As for tools, you usually need a drill (depending on the wall type, a masonry drill bit for brick or concrete, or anchors for drywall), a screwdriver, and possibly a spirit level to align the brackets properly.
With different wall types, you must make sure to use suitable anchors and screws – for example, different ones for wooden walls compared to concrete walls.
My advice: take your time and check how stable your wall is. In older buildings, you may sometimes need special anchors. Otherwise, Ikea usually provides a mounting kit, but if you don’t trust the included anchors, you can also buy better ones at a hardware store.
To summarize:
- Wall mounting is recommended for safety reasons
- Especially important for families with children
- Choosing the right anchor and screw can be tricky depending on wall type
- Tools: drill, screwdriver, spirit level
If you want, I can also provide a step-by-step guide on how to install the mounting properly.
Best regards!
retau
11 Nov 2023 07:42
Hey ren45!!
Great that you asked this question! Wall mounting is really a must for BRIMNES! 😃 Especially if you have young children or pets, it’s an essential safety measure. Just imagine the furniture standing freely and tipping over with a small push – that wouldn’t just be annoying, it could be seriously dangerous!
I attached my pieces directly to the wall and never had any issues. Plus, the furniture feels more stable and of higher quality.
Don’t worry about the installation; Ikea makes it as simple as possible. The important thing is to use the right wall plugs for your walls – for example, cavity anchors for drywall. You can often find advice on this at hardware stores or in Ikea’s online instructions!
I think it’s better to put in a little extra effort during assembly than to have problems later! Get motivated, start screwing, and you’ll enjoy your furniture for a long time! 🎉
fredle
12 Nov 2023 09:55
Hello ren45 and everyone following this,
I would like to contribute a detailed guide to the discussion about the importance of wall mounting for the Ikea BRIMNES.
First of all: Wall mounting is by no means just a recommendation; it is essential for product safety. Many pieces of furniture like this pose a significant tipping hazard if not secured to the wall, especially on uneven floors or under load.
Here is a brief overview of why and how:
- Tipping Risk: BRIMNES is tall and narrow, which means the furniture can easily tip over when weight is applied from above or the side.
- Child Safety: Wall mounting prevents furniture from toppling over onto children in the home.
- Wall Mounting Hardware: Ikea provides a basic set, which in some cases should be supplemented with more suitable anchors.
- Tools Needed: You will need a drill, screwdriver (usually Phillips), a spirit level if possible, and the appropriate fixing materials for your wall type (e.g. concrete, brick, drywall anchors).
- Installation Tips:
1. Always attach the brackets at least at the height of the first or second upper shelf.
2. Choose wall anchors suitable for the wall type. Use cavity anchors for drywall, and appropriate plugs for solid walls.
3. After installation, always check that the mounting is secure.
- Common Mistakes:
- Using anchors made of the wrong material, which do not hold.
- Installing only on drywall without cavity anchors.
- Fixing at only one point per bracket; a single screw per bracket is insufficient.
My conclusion:
Installing the wall mount is not just a recommendation but a safety measure of clear necessity. Anyone who values safety and wants to avoid risks should carry out the installation carefully with the correct fixing materials.
If you want to know more, I am happy to provide a detailed step-by-step guide with specific tips for different wall types.
Best regards!
