ᐅ How stable is the Ikea Pax system with frequent use?
Created on: 10 Feb 2015 18:23
selcuk
selcuk
10 Feb 2015 18:23
Hello everyone, I am currently considering getting an Ikea Pax wardrobe but am a bit unsure about how sturdy these wardrobes really are with frequent and intensive use. Specifically: How well does the Pax wardrobe hold up to the stress of daily opening and closing of the doors, frequent loading and unloading of clothing, as well as occasional adjustments by installing additional shelves or drawers? I am especially interested in whether there are long-term issues such as leaning, warping of the doors, or material fatigue. Who among you has practical experience, particularly with models of maximum width and height? Thanks in advance for your insights!
temeli
10 Feb 2015 19:07
selcuk schrieb:
How well does the Pax wardrobe hold up to the daily wear and tear of opening and closing the doors, frequent loading and unloading of clothes, and occasional adjustments like adding extra shelves or drawers?
Absolutely great! I’ve been using my Pax for over 3 years now, daily and fully loaded, and I can only share positive experiences. Of course, you need to make sure everything is properly screwed together and assembled carefully – that’s important for any piece of furniture. But the wardrobe stays stable, the doors close smoothly, and nothing sticks or wobbles. Plus, the customization options are excellent! If you ever want to add a few shelves or extra drawers, no problem at all.
So, don’t hesitate, the Pax is a real everyday hero! ;-)
CLINTCHEN
11 Feb 2015 08:12
Regarding the stability of the Ikea Pax system under frequent use, various practical experiences have been reported. The construction is based on relatively thin particleboard material, which is reinforced by the frame structure and back panels. It is important to follow the assembly instructions precisely, as improper assembly often leads to instability.
Over time, excessive load or incorrect assembly often results in:
- Warping of the doors caused by unevenly tightened hinges or overloading
- Leaning or tilting of the entire structure due to insufficient attachment to the wall
- Abrasion and minor material wear in frequently used areas
Concerning maximum load capacity, Ikea provides general guidelines that should not be exceeded. With daily opening and closing as well as occasional adjustments, the screws should be checked and tightened if necessary to maintain proper functionality.
reybo
12 Feb 2015 12:46
CLINTCHEN schrieb:
The construction is based on relatively thin chipboard material, which is stabilized by the frame structure and back panels.
Exactly, that’s a key point. The side panels of the Pax are usually 12 mm (1/2 inch) thick, which is not comparable to solid wood cabinets. As a result, the stability largely depends on the proper interaction of the individual components. In particular, the back panel construction – usually a thin hardboard layer – acts as a shear panel to keep the cabinet box in shape.
With frequent use, screws can loosen over time. Therefore, I recommend checking and tightening the screws after the first few weeks and then every few months as needed. For larger and taller cabinets, wall mounting is essential to prevent tipping hazards.
Opening and closing the doors also generates dynamic stresses. The IKEA hinges are durable, but with heavy use, door alignment may be necessary since the hinges have adjustment screws.
If you plan to frequently modify the cabinet or add extra components, it’s wise to consider the load on each panel to avoid deformation. Overall, the Pax system offers a good solution for everyday use if assembly and maintenance guidelines are followed.
LUSIN
13 Feb 2015 07:39
Here are some practical tips for maintaining the stability of the Pax when used frequently:
- Make sure to install the back panel completely and flush, as this greatly increases stability.
- Regularly tighten screws—especially hinges and connecting fittings.
- Always use wall anchors for very large cabinets to prevent tipping.
- Do not overload shelves; more than 15 kg (33 lbs) per shelf can be critical.
This will help keep the cabinet functional even with intensive use over time.
