ᐅ How easy is it for beginners to assemble the IKEA Hemnes furniture?
Created on: 12 Oct 2023 08:23
Fapuso
Fapuso
12 Oct 2023 08:23
Hello everyone, I am planning to get an IKEA Hemnes furniture piece and wonder how easy the assembly really is for complete beginners. I have very little experience with furniture assembly and wanted to know if the Hemnes series is a good choice in this regard, or if it’s better to opt for other models due to the often quite detailed instructions. I am especially interested in tips on common pitfalls, the time needed for assembly, and whether any special tools are required. Who else has had similar experiences and can give me an assessment of how accessible Hemnes really is for beginners?
Tobias
12 Oct 2023 09:11
The assembly of Hemnes is doable for beginners if the instructions are followed carefully. It is important to sort all parts beforehand and take your time. The included tools are usually sufficient; you will only need a hammer and possibly a screwdriver.
TEBILO
12 Oct 2023 10:47
I would suggest taking a more detailed approach to the assembly. While Hemnes is generally beginner-friendly, the complexity varies depending on which piece of furniture from the series you get. Some dressers or beds include many small screws and require a precise order of assembly. I strongly recommend preparing a suitable workspace before starting and patiently following the instructions step by step. The usual process involves:
- Carefully sorting parts and checking for completeness
- Studying the instructions thoroughly and not rushing
- Pre-adjusting screws slightly to make later adjustments easier
Also, be aware that installing dowels or tongue-and-groove joints requires a delicate touch—this is where most mistakes occur. I’m curious, which Hemnes furniture are you planning to assemble? That greatly affects the evaluation.
Fapuso
12 Oct 2023 11:05
TEBILO schrieb:
I wonder which exact Hemnes furniture you are planning? That greatly affects the assessment.
Thanks, that’s a good point! Specifically, I was thinking of the Hemnes dresser with 3-4 drawers, rather than a bed or a large wardrobe. The dresser should mainly be sturdy, without the assembly taking forever. I’m a bit concerned about the stability, especially if I don’t tighten the screws properly or assemble parts incorrectly due to lack of experience.
GiRoyce
12 Oct 2023 12:44
The Hemnes dresser with 3-4 drawers is well suited for beginners. The instructions are clear and include many illustrations, which is very helpful. It is recommended to tighten the screws loosely at first and then fully tighten them at the end to avoid alignment mistakes. If possible, have someone help you, as it is often easier with two people. The materials are sturdy, so stay confident – you can handle this well.
tutan
12 Oct 2023 13:29
That’s something to look forward to! 😄 The Hemnes dresser is actually a great starting point for assembling furniture. The parts usually fit together well, and the screws are quite forgiving if you don’t tighten one perfectly. So: don’t stress about it, you’ll get the hang of the tension quickly. And remember – the assembly itself is already half the battle, after that you’ll have a really nice piece of furniture to be proud of! 💪
