I just assembled my BILLY cabinet and noticed that one of the doors doesn’t close properly. So, my question is: how exactly do you adjust the doors on a BILLY? Specifically, I mean how to set the door so that it sits parallel to the cabinet frame without sticking or creating gaps. Are there special screws you need to turn, and in which direction? Also, I’m interested in whether there is anything to consider regarding the load or type of screws to avoid damage. I’ve already tinkered with the hinges a bit but I’m not sure if I’m doing it correctly.
I would be very grateful for a detailed guide or any tips!
The BILLY doors are adjusted via the hinges.
1. To adjust the lateral position, there are small screws on the hinges that can be turned with a Phillips screwdriver.
2. By turning these screws, you can move the door left or right.
3. For height adjustment, there are usually screws on the hinge plates inside the cabinet frame.
That’s basically it.
Hello sanel,
to fully understand how to precisely adjust the BILLY doors, it’s helpful to look into the details:
The BILLY doors are mounted on concealed hinges with adjustment mechanisms that allow three-dimensional adjustment. This means:
- The lateral adjustment is controlled by a screw on the front of the hinge. Turning this screw moves the door horizontally, along the side of the cabinet, to reduce or balance gaps if the door is misaligned.
- The height adjustment is done via a screw at the base of the hinge where it is fastened to the cabinet. This allows the door to be moved up or down, which is important if the door rubs against the bottom trim or does not close flush at the top.
- The depth adjustment, meaning moving the door closer to or further from the cabinet, is made with another screw on the hinge, usually easily accessible from inside. This ensures a smooth alignment of the door against the frame.
It is important to turn the screws only in small increments for each adjustment and test the door regularly. It is also recommended to remove the door when performing height adjustments to avoid damage.
When making adjustments, make sure the screws are not overtightened, as BILLY furniture is made from a relatively light wood-based material; excessive force can cause damage.
Additionally, some hinges have integrated damping mechanisms. Be careful when adjusting near these dampers to avoid breaking them.
Does this roughly fit your situation, or are you experiencing specific issues with any of the adjustment directions?
PIN66 schrieb:
The BILLY doors are mounted on concealed hinges with adjustment mechanisms that allow for three-dimensional adjustment.Thanks, that helps me a lot. I was unsure because the door sticks slightly at the bottom on the left side when I close it. So, it’s probably the height adjustment that is affected.
Could you please briefly explain how to best remove the door for adjustment? I don’t want to break or damage anything, as the hinges look quite delicate.
sanel schrieb:
Could you briefly explain how to best unhang the door for adjustment?Sure, here is the guide for unhanging the BILLY door:
1. Open the door fully.
2. At the hinges, you will find small plastic or metal levers that act as safety locks to hold the door in place.
3. Depending on the model, gently lift or push this lever up or down to release the lock.
4. Then carefully pull the door forward away from the cabinet – it should come off without force.
Note: If the door does not come off easily, check the lever again to avoid damaging the hinges.
Once the door is unhung, you can adjust the height at the hinge base by turning the corresponding screw a few turns with a Phillips screwdriver.
I recommend making only small adjustments at a time, then rehanging the door and checking if any binding issues are resolved.
If your model has no levers, you might need to loosen the screws on the hinge plate, but this should be your last option to avoid damaging any joints or mounts.
Does this help you?
