ᐅ How well does Ikea Pax withstand heavy loads?
Created on: 17 Jul 2015 08:37
atakanmar
atakanmar
17 Jul 2015 08:37
I am planning to buy an IKEA PAX wardrobe to store not only clothes but also heavier items like boxes with tools and heavy books. My question is: How well does the IKEA PAX system hold up under heavy loads?
Specifically, I am interested in how stable the side panels remain under significant weight, whether the shelves bend or slip out of their fittings, and whether wall fixings are absolutely necessary to safely support the load.
Has anyone had experience with the maximum load capacity of individual PAX components, and are there any tips on how to best reinforce or properly install the wardrobe so that it can handle heavy weight without damage?
Thanks in advance for your insights!
baelku
17 Jul 2015 09:12
The side panels of the PAX are made of thin particle board material, which does not support very heavy loads. The shelves have a maximum load capacity of about 15 kg (33 lbs); exceeding this can be risky. Wall mounting is definitely required, otherwise the wardrobe can easily tip over.
Josan
17 Jul 2015 10:05
Hello atakanmar,
I can understand your concerns well. The PAX system is basically designed for household items and can handle moderate loads without problems. The typical shelves are rated for about 15–25 kg (33–55 lbs), and it’s better to distribute heavy loads across several shelves.
The side panels themselves are made from a thin particleboard composite, which feels sturdy but may give way under too much concentrated load. Ideally, the unit should be wall-mounted using the supplied brackets. This not only improves stability but also increases load-bearing capacity.
If you plan to store very heavy items, it’s also worth considering stronger shelves (possibly metal or thicker boards) or installing additional reinforcements.
I hope this helps!
Danabla
17 Jul 2015 11:43
In addition to Josan:
- The maximum load capacity of the shelves according to the manufacturer is about 15 kg (33 lbs), with even weight distribution.
- The side walls are made of 10 mm (0.4 inch) thick particle board, which appears sturdy but can deform under excessive load.
- Wall mounting is necessary not only for safety reasons but also significantly improves overall stability.
- Reinforcement with additional aluminum profiles, steel beams, or custom inserts is possible and advisable for extra heavy loads.
In my opinion, PAX should not be used for heavier loads without modifications.
tutan
18 Jul 2015 07:21
Hey atakanmar! 😄
PAX is nice, but for heavy items it can be a bit temperamental – fragile in the wrong places, strong when handled properly. The key is wall mounting! That’s what makes the wardrobe really sturdy.
I once had one filled with many heavy toolboxes – I reinforced the shelves with wooden strips, so they didn’t sag. It might not look pretty, but it works perfectly. And if you decide to do this, distribute the load as evenly as possible.
Good luck assembling and loading! 💪
atakanmar
18 Jul 2015 08:17
Josan schrieb:
If you want to store very heavy items, it’s also worth using stronger shelves (possibly made of metal or thicker panels) or installing additional reinforcements.
These kinds of reinforcements interest me the most – how exactly did you solve this, or do you know if IKEA offers accessories for this?
That sounds technically interesting, but probably complicated for a layperson to do by themselves.
Or is it really enough to simply secure the shelves better? What about the stability of the side panels under heavy load over a longer period? Would they warp or break? Your advice is very helpful for me to prepare my decision.
