ᐅ How can door handles be securely attached to an Ikea Pax wardrobe?
Created on: 5 Feb 2020 08:37
Serichar31
Serichar31
5 Feb 2020 08:37
I recently bought an Ikea Pax wardrobe and now want to securely attach door handles. The doors are quite thin, so I’m wondering which screws or fastening methods are really suitable for mounting the handles firmly without them loosening over time or damaging the door.
I’m especially interested in whether it’s better to use special threaded inserts or if the screws supplied by Ikea are sufficient, especially when fitting somewhat heavier or longer handles. Are there any tips on the best way to position the handles to ensure the load is evenly distributed?
Has anyone had experience with recommended screw lengths and types, particularly when extra stability is needed?
Looking forward to your tips and recommendations!
pauPierce
5 Feb 2020 10:58
Hello Serichar31,
Regarding the topic "How to securely attach door handles to Ikea Pax?" there are some important details to consider to ensure the handles not only look good but also stay firmly in place over time.
First, it is important to know that the doors of the Pax system are usually made of coated particleboard or MDF with a thickness of about 16 mm (5/8 inches). This means you can’t simply use very long screws, as this would damage the back of the door. The screws provided are typically matched to the standard handle threads but are often only about 30 mm (1 1/8 inches) long, which may not be ideal for very long handles or higher stress.
Here is a recommended approach:
- Use high-quality screws with the correct thread that are slightly longer (e.g., 35–40 mm (1 3/8 – 1 5/8 inches)) but be careful not to penetrate too deeply.
- To reinforce the door material, you can use threaded inserts or metal sleeves installed on the inside of the door with a drill. This ensures the screw is held securely.
- When mounting, avoid over-tightening the screws, as the material can easily crack.
- Position the handles so that the screws go into more stable areas of the door (for example, avoid placing them right at the edges if possible).
An interesting question is whether the pre-drilled hole spacing on Pax doors fits all common handle drillings. Unfortunately, this is not always the case. If in doubt, you should precisely drill the holes yourself and possibly use larger anchors or reinforcements.
If you use longer or heavier handles (such as steel or solid wood handles), I strongly recommend using threaded inserts. They significantly increase durability.
One final tip: if you want to use threaded inserts yourself, you will need a suitable installation set with either a drive-in or screw-in tool, which you can find at hardware stores.
I’m curious which type of gratified handles you plan to install and whether the doors are coated or painted? This might affect the installation.
kaju67
5 Feb 2020 14:26
pauPierce schrieb:
Here is a method I can recommend:
Thanks for the detailed tips! To summarize it simply: If you want to prepare your Pax part for everyday use, it’s better to use threaded inserts—they provide the extra grip we all appreciate ❤️.
I personally attached my handles with the original screws once (because I was short on time), and after a few months, one of the handles became loose. I believe the issue was that the screws were just too short for the heavier handle.
It’s a good idea to check and tighten them after a few weeks; that way, your cabinet feels maintained from the inside too😅.
Regarding your question about positioning: Try out in advance where the handles sit best, not just visually but also practically for your grip style. Nothing is more annoying than a handle that becomes uncomfortable to use over time!
In short: Take your time when attaching handles; a bit of planning saves you frustration later!
tra_nina
6 Feb 2020 09:14
Regarding the secure fastening of door handles on the Ikea Pax system, there are clear mechanical and construction standards that should be followed.
The doors are typically 16 mm (0.63 inches) thick, which directly limits the allowable screw length when tightening. To securely attach the handles, I recommend:
- Screw length: maximum 35 mm (1.38 inches), depending on the handle thickness; longer screws may damage the back of the door.
- Use of metal threaded inserts (such as Helicoils or similar) to reinforce the mounting points, ensuring they withstand screw forces over time.
- Pre-drilling holes with a diameter slightly larger than the screw diameter to prevent material stress.
- Mounting the handles as close to the center of the door as possible to minimize lever forces on the material when pulling.
Additionally, ensure that the surfaces and materials of the handles are compatible with the screws to prevent corrosion.
Summary: For a long-lasting, secure installation, threaded inserts are recommended, and screws of appropriate length should be used with regard to the material thickness.
Alberto51
7 Feb 2020 11:03
Serichar31 schrieb:
The doors are quite thin, and I’m wondering which screws or fastening methods are really suitable to securely install the handles without them loosening over time or damaging the door.
I completely understand your concerns. I was unsure myself when I first wanted to install the handles on my Pax wardrobe. After careful consideration and a few failed attempts, I found the following approach works best:
I now use metal threaded inserts because they give me the greatest sense of security. At first, I thought it would be too much effort, but it’s definitely worth it—especially if there are children in the house or if the doors are used frequently.
Sometimes it also helps to apply a small drop of threadlocker (for example, medium-strength threadlocker) on the screws to prevent them from loosening due to vibrations.
If you notice during installation that the holes are too large or the material is damaged, a wooden patch inside can often help. You can fix it with wood glue and then drill new holes over it.
I’d recommend doing the installation with a friend so you can check together that everything stays properly aligned while tightening.
In the end, patience and careful work during installation are key to ensuring everything stays stable and looks good.
