ᐅ How can the back panels of Ikea PLATSA be securely and firmly attached?
Created on: 16 Sep 2023 08:17
EmmettpuHello everyone,
I am currently planning the assembly of my Ikea Platsa wardrobe system and have a specific question regarding the back panels. As you may know, the back panels in Platsa are not rigid but rather flexible elements that can be fixed using different methods. Since I place great importance on a secure, durable, and as stable as possible attachment of the back panels (especially to prevent warping of the furniture), I am interested in which fastening methods you would recommend.
Specifically, I am interested in the following:
- Which screws, nails, or clamping techniques work best?
- Are there any tips for attaching the back panel so that it does not give way or sag under heavier loads (for example, when the shelves are fully packed)?
- How do you handle cases where the back panel is slightly smaller or serves only as decoration – is a different method advisable there?
I look forward to your detailed experiences or tips. Thank you in advance!
Hey Emmettpu!
Great question, I’m also really focused on making my PLATSA units extra sturdy! 🙌
So: I always use small screws with wall anchors when attaching the cabinet to the wall. This provides solid stability and prevents the back panel or the entire cabinet from wobbling. The original nails from Ikea often feel too flimsy to me.
For the back panel itself, I often add small corner brackets to secure the panel better—especially for taller units. And always cut everything with miter joints, so the back panel fits perfectly!
Of course, don’t overdo it, but if you want to secure your PLATSA well—go for the screws, and it will last forever! Good luck! 🙂
Back to the topic: The back panels in Ikea PLATSA units are typically non-load-bearing and mainly serve to provide stability and aesthetics. The standard attachment is done with small nails supplied by Ikea.
For a secure and stable installation, I recommend the following approach:
- Use a back panel made of sturdy MDF board (preferably at least 3 mm (0.12 inches) thick).
- Attach the back panel with fine nails or screws that do not cause splitting; screws about 15-20 mm (0.6-0.8 inches) long with a narrow head are ideal.
- Space the fasteners evenly around all sides.
- Additionally, check that the back panel sits flush to avoid any tension that could cause warping.
It is important not to install the back panel with excessive force, as this can lead to frame distortion. For larger cabinets, adding smaller corner brackets or metal fittings can be useful.
This ensures the back panel is fixed securely and stably.
Hello Emmettpu,
I completely understand your concerns. A solid back panel attachment ensures stable furniture and reduces long-term issues.
From my experience:
- Especially with PLATSA, the provided nails offer quick hold, but if you apply too much force, they can damage the back panel or cause the frame to warp.
- Therefore, I recommend pre-drilling the fastening points. Use fine screws (usually 3.5 x 20 mm (0.14 x 0.79 inches)) that you can screw in with light torque. This helps prevent cracks.
- Make sure the back panel rests flat without any tension.
- Extra tip: For particularly tall shelving units, you can install small steel brackets at the top on the inside of the side panels to add extra stability.
If you’re uncertain about cutting or pre-drilling, take your time. The best stability comes from precise measurements and gentle pressure.
I hope this helps you out.
From my experience:
Hello everyone!
I have put together a short guide on how I securely install back panels on Ikea PLATSA units:
1. Preparation:
- Check that the back panel fits properly – it should lie flat against the rear edges of the carcass without bowing.
- If necessary, trim the back panel with a sharp knife or sandpaper.
2. Fastening materials:
- Single-use back panel nails come with the original set, but I prefer using 1.2 x 16 mm (approximately 1/16 x 5/8 inches) finishing nails, which can be found at hardware stores.
- Alternatively, use small chipboard screws, about 3 x 20 mm (approximately 1/8 x 3/4 inches) in size; pre-drill well.
3. Installation technique:
- When using nails: secure the top edge first, then nail in the sides.
- The resistance during nailing should not be too high to avoid cracking.
- For screws, always pre-drill and insert slowly; do not drive too deep, as this can cause the back panel to swell.
4. Additional tips:
- For large or tall furniture, small metal brackets at the corners can provide extra support.
- Regularly check during assembly to ensure the back panel does not warp.
Summary: Precise fitting, careful fastening with quality materials, and regular inspection are key for a stable back panel on PLATSA units.
Good luck with your building project!
1. Preparation:
4. Additional tips:
