ᐅ How do you properly sand the wooden edges of Ikea PLATSA units?
Created on: 30 Jul 2019 08:37
heide57
Good morning everyone, I’m currently facing a small DIY issue and hope you can share your expertise: How do you properly sand the wooden edges of the Ikea Platsa furniture without damaging the surface or causing the edges to fray?
In my previous attempts, the edges often appeared uneven and somewhat rough. I suspect I might be using the wrong grit of sandpaper or the incorrect technique. I’m also wondering if it’s necessary to apply a sealant or some kind of treatment after sanding to prevent the edges from swelling or wearing down with later use.
Could someone please explain step by step the best way to do this, which materials (sandpaper, sponges) are needed, and how much pressure should be applied? Thanks in advance!
Tevin
30 Jul 2019 12:08
heide57 schrieb:
Is it advisable to treat the PLATSA edges with a special cleaner or degreaser before sanding?
In general, it is enough to wipe the edges with a dry cloth before sanding to remove dust or dirt. Degreasing is only necessary if there are adhesive residues or similar contaminants.
heide57 schrieb:
How much should the edges actually be rounded off?
A very subtle rounding is sufficient for PLATSA edges. The goal is to smooth sharp edges, not to significantly alter the edge profile visually. A radius of 1 to 2 millimeters (0.04 to 0.08 inches) is usually enough. It is important to sand evenly to avoid any uneven or unattractive spots.
Tause
31 Jul 2019 07:46
A brief critical note: Is sanding the edges of PLATSA really done frequently to fit properly? The melamine coating is quite thin and can be easily damaged.
So, anyone who sands too much risks uneven surfaces or exposing the underlying material. This can then swell or fray.
Perhaps it is worth considering using edge trims or self-adhesive edge banding for the PLATSA edges instead. These last longer and are less likely to damage the surface.
praWarre69
31 Jul 2019 08:05
Tause schrieb:
Maybe one should consider using edge protectors or self-adhesive edge banding for the PLATSA edges.
That's true, but if you like to do the work yourself, sanding is also a good way to fix small uneven spots. Just take it easy and check your progress frequently.
Like with any good craftsmanship: stay calm, have sandpaper and a sponge on hand, and work carefully step by step!
