Hello everyone, I have a problem with my Malm bed frame from Ikea, which after several years of use has started to become wobbly and creaks at some of the joints. Specifically, it concerns the connection of the wooden parts at the bed runners and the center support beam, where screws sometimes become loose or wood crushing is visible. My question is: How do you properly repair Malm bed frames so that stability is maintained in the long term? Which materials and tools are absolutely necessary for this, and are there any tips to reinforce especially stressed areas without affecting the original design? I would appreciate it if someone with experience in these common weak points could recommend step-by-step what I should do. Thanks in advance!
deoke schrieb:
If screw holes are worn out, be sure to use wood filler or properly cut wooden dowels to reinforce the wood. This method is scientifically recognized and is also recommended in Ikea’s manual as a repair option for damaged chipboard joints.
Regarding material selection: The wood glue should be at least D3 or D4 rated, meaning water-resistant and durable. The wooden dowels should have a minimum diameter of 8 mm (0.3 inches) to ensure a stable connection.
Recommended tools:
- Cordless drill/driver with torque control
- Clamps for securing parts
- Sandpaper for finishing
- Possibly a drill bit matching the dowel diameter
It is essential to retighten all joints firmly after the repair but avoid overtightening to prevent the wood from fraying again.
Both the longitudinal and cross supports must be checked on both sides, as the retainer or glued joint often loosens at the connection points. Errors here can cause the structure to become unstable again.
Thanks for the great tips so far! I would be interested to know if Breno has already carefully checked the headboard or the back panel during the repair, as these parts are often also responsible for the stability of the entire bed frame.
Also, does anyone have experience reinforcing the screw holes with wooden strips? I recently did this on another piece of furniture and achieved a very sturdy solution.
naudan schrieb:
Has anyone had experience reinforcing screw holes with wooden strips? Oh yes, that’s a really great method! Simply attach wooden strips to the sides, which helps distribute the load evenly 🙂 I did it myself, and since then the bed hasn’t creaked anymore. It’s important to sand the edges of the strips well to avoid unpleasant rubbing noises when moving in bed.
Also, I recommend disinfecting everything thoroughly beforehand, especially if the bed is older – no one wants any unpleasant surprises later 😉
A small tip at the end: after applying the glue, place a as evenly distributed a weight as possible on the frame to help the glue cure properly. Good luck!
