ᐅ How to Properly Repair Malm Bed Frames?
Created on: 16 Dec 2015 21:07
Breno
Breno
16 Dec 2015 21:07
Hello everyone, I have a problem with my Malm bed frame from Ikea, which after several years of use has started to become wobbly and creaks at some of the joints. Specifically, it concerns the connection of the wooden parts at the bed runners and the center support beam, where screws sometimes become loose or wood crushing is visible. My question is: How do you properly repair Malm bed frames so that stability is maintained in the long term? Which materials and tools are absolutely necessary for this, and are there any tips to reinforce especially stressed areas without affecting the original design? I would appreciate it if someone with experience in these common weak points could recommend step-by-step what I should do. Thanks in advance!
blaix
16 Dec 2015 21:22
Breno schrieb:
How do you properly repair Malm bed frames to ensure long-term stability?
That’s an interesting question, but I believe we should first clarify whether the problems are primarily mechanical or material-related. In my experience, the issue is often not the screw head itself, but the particleboard used in the furniture, which fibers out due to stress.
So, to improve stability, I think the damaged wood needs to be reinforced, possibly with wood glue and suitable inserts. Simply replacing the screws without addressing the wood is only a temporary fix. Does anyone have proof or experience showing that just changing the screws in Malm frames provides a lasting solution?
JUANFU
16 Dec 2015 21:58
It’s great to see so much thought being put into this! 🙂
About six months ago, I had a similar issue with my Malm bed and simply attached plywood strips to the bed runners using screws to distribute the pressure. This completely eliminated the creaking, and the stability has been excellent ever since!
My advice: avoid cheap wood glue; use waterproof glue instead, and make sure everything is thoroughly dried! It’s definitely worth the effort. Good luck!
deoke
17 Dec 2015 08:36
JUANFU schrieb:
Plywood strips fixed to the sled runners with screws to distribute the pressure.
That’s already a good approach. I’d like to go a bit deeper, as with Malm bed frames, not only the sled runners but also the center support beam play an important role in load distribution.
The first thing to check is whether the joints between the sled runners and the center support beam are still tight. Loose screws here often cause creaking. For the repair, you should proceed as follows:
1. Slightly loosen all screws in the connections.
2. Apply wood glue (please use a dedicated wood glue, not an all-purpose adhesive) thoroughly to all joining surfaces.
3. Then retighten the screws, making sure not to squeeze the wood, so do not overtighten.
4. If screw holes are worn out, be sure to fill them with wood filler or use properly sized wooden dowels to reinforce the wood.
5. A drying time of at least 24 hours under load is crucial.
Additionally, as JUANFU suggests, you can add cross braces or metal or wooden corner brackets to increase stability.
Breno, maybe you can specify exactly which part is wobbly? That way, the repair can be recommended more precisely.
Tatovin
17 Dec 2015 09:12
Replace screws, use wood glue, do not tighten screws too much. Use wood filler for frayed holes.
Additional reinforcements can help. That's all you need.
Shawn38
17 Dec 2015 10:37
I would like to add that it is very important to use the right tools when repairing the Malm bed frame. For example, a good cordless drill with torque control helps prevent over-tightening the screws, which is especially important when working with particle board.
Additionally, clamps can be helpful during gluing to hold the parts firmly together until the glue has fully set.
Important: Do not apply any load immediately after the repair; it is better to let it rest for a day. For the screws, I recommend using galvanized or even stainless steel options—especially if moisture resistance is required.
Depending on the extent of the damage, it may also be worthwhile to order replacement parts or new screws from Ikea—they are sometimes surprisingly affordable and perfectly fitting.
