ᐅ How do I repair the Malm bed frame after a fall?
Created on: 20 Jan 2023 08:23
tolupu
tolupu
20 Jan 2023 08:23
Hello everyone, I have a problem with my Malm bed frame, which unfortunately got damaged after a fall. Specifically, the lower frame that supports the mattress has cracked on one side and is no longer stable. The fall height was about 40 cm (16 inches), the frame is made of pine wood, unreinforced, and I suspect that the supporting crossbeam is broken or at least severely weakened. Now I am wondering how to best approach this repair without having to replace the entire frame. What tools and materials do I need for this, and is there a proven method to restore the stability? I would appreciate any advice that helps me make the bed safe and stable again!
tyson51
20 Jan 2023 09:15
Hello tolupu, your issue is definitely solvable, but it depends on how severely the wood is damaged. If the crossbeam is cracked, you can reinforce it using wooden dowels and wood glue. It is important to first sand the break area clean to improve the bonding surface. Clamps are suitable for holding it in place and should remain attached for at least 24 hours. Make sure to use a PVAC-based glue (wood glue) for a secure bond. If the wood is too damaged, it might be more sensible to replace the beam, if possible with a custom-cut piece of pine wood matching the dimensions.
retau
20 Jan 2023 09:47
That sounds frustrating, but don’t worry, every damage can be repaired! 🙂 For a small repair, I recommend measuring carefully first and then getting some wood glue and a few new screws. Sometimes a metal angle bracket, which you can attach on the inside, also helps. This provides extra stability – really great! You’ll definitely manage to get the bed back in good shape soon! 🙂
barda6
20 Jan 2023 11:03
tyson51 schrieb:
with wooden dowels and wood glue for stabilization
I can confirm that. Drill holes for the wooden battens, coat everything with glue, clamp together, and let dry. Screws should be used only as assistance, not as the main fixing.
Marlenepa
20 Jan 2023 11:45
Hello tolupu, it’s good that you described the issue in detail. With Malm beds made of pine wood, it is indeed common for the crossbars to get damaged in a fall. If the crack is clean and not too large, I can recommend the following procedure:
1. Sand and clean the area thoroughly to remove old paint residues and dirt.
2. Apply plenty of PVAC-based wood glue.
3. Position wooden strips or dowels on the broken side.
4. Clamp tightly with bar clamps to ensure no gaps remain.
5. Let it dry for at least 24 hours.
Additionally, if the construction allows, you can reinforce the stability by screwing metal brackets from the inside. It is also important to check before the repair whether other parts are cracked or loosened. I hope this helps! Feel free to ask if any of the steps are unclear.
tolupu
20 Jan 2023 12:11
Thank you very much for the helpful tips. I would like to know the best way to install wooden dowels: Should I drill the holes slightly offset on both sides of the crack? And how many dowels would be appropriate for a crack about 30cm (12 inches) long? Is there a specific drill bit size I should use to achieve the strongest hold? Wooden battens are also an option, but I prefer the repair to be somewhat more flexible. Thanks to everyone!
