ᐅ How should the painted surfaces of BILLY be properly maintained?
Created on: 21 Jun 2019 09:14
KEPURU
KEPURU
21 Jun 2019 09:14
I would like to start a discussion on the topic: How to properly care for the painted surfaces of Billy?
Specifically, I’m interested in which cleaning products and methods are suitable for maintaining the smooth, painted surface over time without causing damage or unwanted wear. Are there any special precautions to consider? For example, due to the particular paint layers or frequent use.
What experiences have you had with recommended care products? Does a damp microfiber cloth work better, or are special polishes more effective? I look forward to practical tips and also advice on things to avoid.
Thank you and best regards!
LOSAR
21 Jun 2019 09:37
It is best to use a damp, soft cloth – avoid harsh cleaning agents.
No abrasive cleaners, as they can damage the surface.
Simply wipe regularly and allow to dry thoroughly.
Shawn38
21 Jun 2019 10:02
Hello KEPURU,
I have been maintaining my BILLY shelves for years like this: I use a slightly damp microfiber cloth to remove dust and dirt. It’s important that the cloth is not too wet, as standing water can damage the paint finish.
Regarding cleaning agents, I recommend avoiding aggressive or solvent-based products. Instead, I use a mild dish soap if something is a bit stubborn, but even then only very sparingly.
In general: no abrasive sponges or scouring agents.
Also, fingerprints and stains should be wiped off quickly before they dry.
I hope this helps you! 🙂
Linavin
21 Jun 2019 10:33
Interesting introduction here!
However, I would like to critically question whether the universal solution of “microfiber cloth and mild dish soap” is always the best way to care for these surfaces.
BILLY furniture uses different types of finishes depending on the manufacturing process (lacquer or polyurethane?). Therefore, the chemical resistance can vary significantly.
Shawn38 schrieb:
mild dish soap, if something is a bit more stubborn
It would be helpful to know exactly which dish soap is being used – some contain surfactants that do not interact well with polyurethane.
Also: What alternatives to standard products might improve durability in the long term? Should waxes or specialized polishes perhaps be considered?
I look forward to well-founded advice, ideally including background information on the types of finishes.
putan
21 Jun 2019 11:01
Hey everyone 🙂
I’m casually using the microfiber cloth as recommended, but every now and then I treat my BILLY shelf to a little care routine: a bit of furniture polish to keep the finish shiny and the surface “healthy,” so to speak.
Of course, only sparingly and carefully—don’t apply thick layers, or it will get sticky.
Linavin schrieb:
Should we maybe consider waxes or special polishes?
I think the shelf is not too valuable for that—a little maintenance does it good, and you can tell the difference :-)
The important thing is to buff it well afterward so no residue remains.
So, a bit of love for the BILLYs, but nothing over the top 🙂
enrique7
21 Jun 2019 11:40
I would like to add to this: it is indeed important to know the exact type of paint or coating. According to IKEA, the BILLY shelves are usually coated with polypropylene coatings or melamine resin finishes, which require little maintenance but are sensitive to solvents.
Linavin schrieb:
BILLY furniture features different types of coatings depending on the production process
A confirmation from IKEA or a product specification would be helpful here, as using the wrong maintenance method can damage the surface more than it helps.
I recommend testing any polish or wax on a small, inconspicuous area before applying it more broadly.
Another important tip: do not use abrasive cleaners or paper towels, as they can scratch the painted surface.
