ᐅ How can I secure Billy shelves in rental apartments without drilling into the walls?
Created on: 16 Nov 2017 18:07
Dijapo
Dijapo
16 Nov 2017 18:07
Hello everyone, I have a question and hope to benefit from your experience: How can I securely fix my Ikea Billy bookcases in a rental apartment without drilling into the walls? Since I don’t want to leave holes in the walls, traditional wall plugs and screws are not an option for me. Of course, I want to install the bookcases firmly and safely, as they are quite tall and fully loaded, so that nothing can tip over. Does anyone have tips on how to secure Billy bookcases without drilling? Maybe solutions with tension systems, special stability methods, or other clever ideas? Thanks in advance for your suggestions!
laureo
16 Nov 2017 18:45
Hello, Dijapo. In general, it is difficult to securely fasten Billy shelves without drilling into the wall, especially for shelves carrying heavier loads. One option is to stabilize the shelves by tensioning them between the floor and ceiling using wall protectors, also known as tension poles. This method fixes the shelves in place using a rod between the floor and ceiling without damaging the wall. However, you need to ensure that the ceiling is strong enough and that the poles are firmly installed; otherwise, the shelf could tip over. Alternatively, edge protectors or special furniture stoppers can help improve stability.
popodi
16 Nov 2017 19:12
Hey Dijapo, I had the same problem! 🙂 My trick was to buy extra sturdy shelves and load the unit quite heavily towards the bottom, then put some rubber pads under the feet to prevent slipping. Additionally, I hid it behind a lightweight curtain, which acts like a “wall” – basically a pressure-relief element. Not a perfect solution, but it works surprisingly well. And all without any drilling! 🙂
TOSAN
16 Nov 2017 19:39
The simplest solution is a tension system. A rod is placed between the floor and ceiling, with a shelf attached to it. No drilling is necessary.
kulau
16 Nov 2017 20:10
To address your concern effectively, it would be helpful to know the ceiling height and how heavily the shelves are expected to be loaded. The Billy shelves are generally not designed to stand freely without support. That’s why a so-called “ceiling tension system” is recommended, as mentioned earlier. These systems use two vertical tension rods, usually made of steel, that extend from floor to ceiling and secure the shelf in place. The advantage is that no walls are stressed or damaged. Important: the ceiling height should not be too high, as this compromises stability. Additionally, the tension rods should have rubber coatings to avoid damaging ceiling and floor surfaces. Alternatively, you could consider heavy-duty furniture anchors, such as corner brackets used with the Ikea Billy, to minimize the risk of tipping. Another idea is to stabilize the shelf by placing a narrow cabinet next to it, which is fixed to the wall (for example, a wardrobe or a radiator cover), to reduce the risk of tipping as much as possible.
LOSAR
16 Nov 2017 20:37
Tensioning systems are the preferred solution. Stability is hardly achievable without drilling.
