ᐅ How do you properly care for Ikea Brimnes laminate furniture?
Created on: 12 Jan 2020 21:37
kupar47
kupar47
12 Jan 2020 21:37
Hello everyone, I am looking for detailed and practical advice on the proper care of Ikea Brimnes laminate furniture. Since these pieces are heavily used in our household, I want to make sure I maintain them optimally without causing any damage. I am particularly interested in tips for gentle cleaning, preventing surface damage, and removing stains without harming the laminate finish. Are there any specific cleaning products that are especially recommended, or substances that should definitely be avoided? Additionally, I am curious if there are regular maintenance routines that can help extend the lifespan of the coating. I look forward to well-informed answers and shared experiences!
fugolo
13 Jan 2020 07:52
Brimnes laminate furniture has a surface that is durable but will look good for much longer with proper care. Here are some helpful tips for cleaning and maintenance:
- Use a soft, lint-free cloth or a microfiber cloth for wiping.
- For daily cleaning, plain water or a mild soap solution is usually sufficient.
- Avoid aggressive or abrasive cleaners, as they can damage the laminate coating.
- For tougher stains, specialized laminate cleaners or mildly alkaline, pH-neutral cleaners are recommended.
- Grease stains should be removed promptly with a gentle dish detergent and warm water.
- Avoid letting water sit on the surface; dampen the cloth lightly and dry the surface thoroughly afterward.
- Scratches can sometimes be lessened with special laminate care products or polishes; always follow the product instructions carefully.
Additionally, when using the furniture, avoid placing sharp or pointed objects directly on the surface and use coasters or mats for hot or moist items.
Regular gentle cleaning and avoiding harsh chemicals are key to the long lifespan of Brimnes laminate furniture.
Tatovin
13 Jan 2020 09:13
I keep it simple: no abrasive cleaners, no harsh chemicals. Just wipe down with a damp cloth, then dry. Treat stains with mild soapy water, which is completely sufficient.
rubybi
14 Jan 2020 11:08
To add: neutral cleaning agents without alcohol, ammonia, or solvents are best. These substances can quickly damage laminate flooring.
kupar47 schrieb:
if there are regular maintenance routines that extend the coating's lifespan
Yes, indeed. I recommend weekly cleaning with a slightly damp cloth to remove dust and dirt. Afterwards, please wipe the surfaces again with a dry cloth to avoid moisture damage.
Additionally:
- Avoid prolonged direct sunlight exposure, as it can fade the surface.
- Use coasters and soft felt pads under decorative items to prevent scratches.
To remove stubborn stains, you can try a mixture of water and a few drops of vinegar, but remember: do not apply too much liquid and dry quickly.
If scratches occur, there are special laminate repair kits that can conceal minor damage.
I hope these tips are helpful!
