ᐅ How can you prevent wobbling in IKEA BRIMNES furniture?
Created on: 19 Jan 2022 09:27
V
Viktorios
V
Viktorios
19 Jan 2022 09:27
Hello everyone, I recently bought an IKEA Brimnes piece of furniture, specifically a TV stand unit, and I noticed that it wobbles slightly when I use it or lean against it. I have already followed the standard assembly instructions and tightened all the screws properly, but the wobbling persists. I suspect it might be related to the design or possibly uneven floors. My question to the community is: How can you prevent wobbling with the IKEA BRIMNES furniture? Are there any special tips for assembly or additional measures that can be taken to improve stability? I would also appreciate advice on tool usage or adjustments that have proven effective. Thanks in advance!
SUFOJE
19 Jan 2022 09:55
Hello Viktorios, your issue with the wobbling BRIMNES furniture is quite common since the piece has flat feet that don’t automatically compensate for uneven floors. I would recommend going through the following steps: - Use a spirit level to check the alignment of the furniture – often the floor is the key factor. - If the floor is uneven, small shims or felt pads placed under the feet can help stabilize it. - Make sure all screws and connectors are securely tightened, as they might have loosened slightly during transport or assembly. - Optional: An additional wall bracket (if not already installed) can significantly improve lateral stability. In general, proper alignment and securing the furniture to the wall is also advisable for safety reasons. Let me know if you have any further questions about implementation!
V
Vinlen
19 Jan 2022 10:21
SUFOJE schrieb:
If the floor is uneven, small washers or felt pads placed under the legs can help to stabilize the furniture.
I can confirm this. Sometimes just a thin pad is enough to make the furniture stable. Additionally, you should check all screws at the joints and, if necessary, tighten them with the appropriate torque. The BRIMNES design is not meant for very uneven floors, so leveling is essential.
LOJOPAR
19 Jan 2022 12:37
In addition to the previous input, here is a brief guide on how to systematically reduce wobbling:
1. Completely disassemble the furniture and inspect each structural step – some screws may be loose, or assembling in the wrong order can cause wobbling.
2. Tighten screws exactly according to the instructions, but do not overtighten, as this can damage the wood.
3. Level the base by placing felt pads, self-adhesive foam rubber strips, or small plastic washers under each foot.
4. Always use wall fasteners; IKEA usually provides brackets that secure and stabilize the furniture.
5. If the furniture still wobbles, adding internal reinforcements, such as narrow metal brackets in the corners, can help.
6. Finally, check for stable standing by applying gentle pressure from different sides.
Pay particular attention to the floor surface and wall fasteners, as these are usually the main causes of wobbling.
SETHBLA
19 Jan 2022 14:03
Secure the walls, level the feet with washers, and tighten all screws. That’s all you need for BRIMNES.
V
Viktorios
19 Jan 2022 16:15
LOJOPAR schrieb:
Always use wall fasteners; IKEA usually includes brackets that secure and stabilize the furniture.
Thank you for the detailed instructions. I have one more question: So far, I haven’t anchored the BRIMNES to the wall because I wanted to keep the furniture movable. Is there a way to significantly reduce the wobbling without wall fasteners, or would there always be a risk? I have already tried using washers, but unfortunately, it still wobbles.
