ᐅ How do you remove sticker residue from Kallax shelves?
Created on: 14 Mar 2023 08:23
Ellalen
Ellalen
14 Mar 2023 08:23
I recently bought a Kallax shelf from Ikea and applied stickers to it, which I now want to remove. Unfortunately, some sticky residue remains on the white surface, and I am looking for a gentle but effective way to remove this residue without damaging the surface. Has anyone had experience with cleaning adhesive residue from a Kallax high-gloss or laminate shelf? I also want to avoid using harsh chemicals that could harm the finish. I would appreciate any tips, especially if you know methods that work well and require little effort.
noken
14 Mar 2023 09:12
Hello Ellalen,
I know this problem well; those adhesive residues can be really annoying. I feel like I spend hours dealing with stuff like that... 🙂
What has usually helped me is first soaking the residues with warm soapy water, then gently scraping them off with a plastic card (something like an old credit card). You have to be careful not to scratch the surface.
If that’s not enough, I sometimes use a bit of isopropanol or nail polish remover applied with a cotton swab, but you should always test this first on an inconspicuous area, as it can affect the paint.
I hope this information already helps you a bit. I’m also curious to hear what others recommend—maybe there are even smarter solutions out there.
Bilujon
14 Mar 2023 11:07
Photovoltaic system adhesive residues can be effectively removed with a specialized adhesive remover. Otherwise, oil (e.g., olive oil) can help. Let it sit briefly, then wipe off.
CARLA
14 Mar 2023 12:45
To remove sticker residue from Kallax shelves, I recommend a systematic approach:
1. Mechanical removal: First, gently loosen the adhesive residue using a plastic card or a soft scraper to avoid scratches.
2. Chemical removal: Special adhesive removers based on citrus or solvents, such as products containing D-limonene, are effective. Apply with a cloth and test on an inconspicuous area beforehand.
3. Alternative household remedies: A cloth soaked with a little cooking oil can dissolve adhesive residue. Afterwards, clean with soapy water to remove any oil residue.
Finally, harsh solvents like acetone should be used with extreme caution, as they can damage the laminate. The use of abrasives is not recommended.
noken
15 Mar 2023 07:59
CARLA schrieb:
For removing sticker residue from Kallax shelves, I recommend a systematic approach:
I find this very helpful, thank you! Especially the tip about products containing d-limonene sounds reasonable and gentler than harsh solvents.
I’m wondering if anyone has specific product recommendations or experience with particular products available at hardware stores? I often get the impression that product descriptions don’t reveal much about their actual effectiveness.
gregto
15 Mar 2023 10:34
I would like to approach this from a more fundamental perspective, as many of you have already shared good tips.
Sticker residues usually consist of adhesive substances based on oil, acrylic, or resin. Therefore, it is crucial to know the type of surface you are treating (e.g., laminated, painted, laminate flooring) in order to select the appropriate cleaning agents.
If you are unsure, I recommend starting with a minimally invasive method:
- First, gently soak the area with warm water, possibly combined with dish soap.
- Then carefully remove the residue using a microfiber cloth or a plastic card.
If this does not work, products based on citrus oil (D-limonene) or a low concentration of isopropanol can be suitable. It is also important to wipe the surface with clean water after removal to avoid residues that could damage the coating.
Ellalen schrieb:
Ich möchte auch vermeiden, dass aggressive Chemikalien den Lack angreifen.
This is a very important point, as acetone or solvents should be used very cautiously on Ikea laminate.
I hope this helps, and I am glad if I could contribute to some clarification 🙂
