ᐅ How do you attach a mirror to the doors of a Pax wardrobe?
Created on: 23 Jan 2020 08:37
mikapar
mikapar
23 Jan 2020 08:37
I am currently facing the challenge of securely and stably attaching a large mirror to the doors of my Ikea Pax wardrobe. Specifically, I am looking for the best mounting methods to fix the mirror permanently without causing any damage. I am considering whether to glue the mirror directly onto the doors, use specialized brackets, or opt for screws and wall plugs. It is also important for me to get advice on preparing the surface and on materials that will hold long-term without the mirror wobbling or falling off when the doors are used.
Does anyone have experience mounting mirrors on Pax wardrobe doors? What approach would you recommend, especially for large mirrors? I look forward to your tips and advice.
FAZAR
23 Jan 2020 10:22
Hello mikapar,
If you want to attach a mirror to the doors of a Pax wardrobe, there are several established methods I can explain to you in detail.
First, it is important to know whether the doors are made of wood, MDF, or another surface, as this affects the choice of attachment method. For most cases, these three methods are particularly suitable:
- Installation with mirror adhesive: A special silicone-based mirror adhesive has the advantage that no bolts or screws are visible. The adhesive is applied to the back of the mirror in dots or strips. Make sure to use only mirror adhesive that is explicitly designed for mirrors—regular adhesives will eventually damage the reflective coating on the back. The bonding surface must be clean, free of grease, and dust-free before application. Press the mirror on lightly and then allow it to cure for 24 hours.
- Mirror clips or clamps: These are attached to the edges of the door, where they hold the mirror firmly. The advantage is that the mirrors are easier to replace. However, clips can visually alter the appearance somewhat and require a certain door thickness and stability.
- Screws with rosettes: For a very secure connection, especially with large, heavy mirrors, screws with matching plastic or metal washers provide a solution. Small drill holes with protective rings need to be made where the screws pass through the mirror to prevent cracking. Usually, backing plates or reinforcements are mounted on the door before the screws are inserted.
One important note: attaching mirrors to the inside of the doors usually works better due to lower stress from movement. If the mirrors are mounted on the outside surfaces, which are often subject to strain, make sure the attachment is very secure. Additionally, check whether the door hinges can handle the extra weight without problems.
Before starting, please carefully measure how much weight your doors can support, and add reinforcements if necessary. Also, consider the total load depending on the size of the mirror.
Could you tell me exactly what type of doors you have and the dimensions of the mirror? Then I can give you even more targeted advice.
JORDON
23 Jan 2020 14:05
FAZAR schrieb:
If you want to attach a mirror to the doors of the Pax wardrobe, there are several established methods that I would be happy to explain to you in detail.
Absolutely! Well explained, FAZAR. Especially with IKEA furniture, you often don’t want to just start drilling randomly – after all, you don’t want to cause more damage than necessary.
Personally, I find the option using mirror adhesive really great because it doesn’t change the look of the doors. Just apply small dots of mirror adhesive, press the mirror on, let it dry well – done.
If you want to be a little safer, you can also apply small, transparent adhesive pads in the corners. This gives extra support when the door is actually opened, without the mirror wobbling.
And yes, it always feels a bit nerve-wracking to attach a large piece of glass to the door – but with the right adhesive and a clean surface preparation, it really holds firmly.
One more tip: the doors should be really clean, grease-free, and dry. Wipe them down with alcohol or glass cleaner before installation. Then: be patient, let it cure properly, and you’ll enjoy it for a long time! 😊
Tause
24 Jan 2020 09:43
JORDON schrieb:
Personally, I find the option of using mirror adhesive really great because it doesn’t visually alter the doors.
That’s a valid point, but only if the adhesive technique is done properly—using the wrong or low-quality adhesive can cause long-term damage to the mirror.
FAZAR schrieb:
At the points where screws go through the mirror, small drill holes with protective rings must be made to prevent the mirror from cracking.
This raises the key question for me whether the effort of making such drill holes is justified at all, or if indirect mounting solutions like clamp or bracket systems might be a better option—especially regarding future disassembly and preserving the door surfaces.
I would also add that, for large mirrors on the Pax, it’s important to consider how sturdy the door hinges are and whether the extra weight might affect their alignment or potentially cause the door to sag over time.
It would be interesting to hear about real-world experiences and whether anyone has had lasting issues with loose doors after installing mirrors.
In general, I tend to recommend indirect mounting with hardware that avoids penetrating the mirror to prevent unpredictable consequential damage.
