ᐅ How can I use IKEA Besta as a room divider and make it feel cozy?
Created on: 29 Jul 2022 08:23
wulframHello everyone, I’m currently considering how to cleverly divide my living room into two zones without completely losing the open feel of the space. I’m particularly interested in how IKEA Besta systems can be used as room dividers. The furniture should not only serve as a partition but also create a cozy and stylish atmosphere. My specific question: How can I design IKEA Besta as a room divider so that it provides practical storage while also looking attractive and homely in the room? Do you have any tips on layout, color choices, and decoration, or any warnings about potential issues when using it as a room divider? Thanks in advance!
Regarding the use of IKEA Besta as a room divider, the following can be said: Besta is well suited due to its modularity and the ability to combine elements in different heights and widths. For a cozy design, I recommend: - A combination of open and closed compartments to create flexible storage and display space. - Using warm colors or wood veneer finishes for the fronts instead of the standard white to add a more homely feel. - Integrating lighting, such as LED strips inside or on shelves, to create atmosphere. - When positioning, check stability, as Besta is not originally designed as a room divider; if necessary, secure it or add back panels. Important: Consider not only functionality but also how it harmonizes with the rest of the interior.
Hello wulfram, I would add that when setting it up, you should make sure to choose the compartment height so that it divides the space optimally without overwhelming it. Besta is flexible, which makes design easier. Also, be careful not to overload items in the room divider to maintain openness. For coziness, use textiles like small baskets made of natural fibers, as well as some personal decorations that work well in the open compartments.
Friedrich29 Jul 2022 11:12I know that sometimes I worry room dividers might make a space feel too cramped or unwelcoming. That’s why I appreciate that this discussion also highlights the importance of creating a cozy atmosphere. Especially the combination of open elements and subtle decorations can help achieve a sense of both openness and comfort at the same time. I would also try to include things that are personally meaningful, so you don’t feel like you’re just passing by the divider, but rather see the piece of furniture as an integral part of the living space.
KARJU schrieb:
When positioning, stability should be checked because Besta is not originally designed as a room divider; if in doubt, secure it or add back panels.I consider this a crucial point. However, I wonder how many users actually do this. An apartment with high-frequency use definitely requires solid securing; otherwise, there is a risk of tipping. Are there any specific experiences regarding this? A recommendation on load distribution would also be helpful. I am also concerned whether the material thickness of the Besta components remains sufficiently stable over a longer period when used as a freestanding piece of furniture.
