ᐅ How can I securely attach Billy bookcases to drywall?
Created on: 28 Dec 2020 08:23
Kekar
Hello everyone, I am planning to mount several IKEA Billy bookcases on drywall partitions in my apartment. Since these walls are less load-bearing than solid walls, I want to ensure the installation is stable and secure so that heavy books and decorations can be supported without any issues.
I am especially interested in which anchors or fasteners you would recommend, whether there are any specific mounting techniques, and if there are any important considerations regarding load distribution. It would also be helpful to know which mistakes to avoid to prevent any damage to the drywall.
Thank you in advance for your tips and experiences!
O
onron
29 Dec 2020 07:48
To locate the substructure, I use an electronic stud finder or a magnetic metal stud detector. This allows you to accurately identify the position and spacing of the metal studs.
Direct screwing into the studs provides the most stable option – each screw typically holds well over 30 kg (66 lbs). For shelving units like Billy shelves, I would secure them with at least three attachment points per unit.
If no studs are available in the right place, horizontal wooden battens can be mounted using hollow wall anchors as load distributors, and the shelf can then be attached to these.
chen67
29 Dec 2020 10:25
Kekar schrieb:
I would be worried about how to securely fix the batten if there is only drywall behind it.
This is exactly where expanding cavity anchors come in—they grip firmly behind the board. Normally, they can handle quite a bit of load if installed correctly.
And of course, using a stud finder is the safe bet if you want to fix directly to the studs.
Sometimes a combination works best: wooden batten plus cavity anchor equals double the security :-)
Devin
29 Dec 2020 14:53
For shelves on drywall: use hollow cavity metal anchors, with at least 3 fixing points. If possible, attach directly to the studs.
Using a wooden batten as a spacer provides better support.
DUVIN
30 Dec 2020 08:07
Don’t forget not to overload the drywall. Although Billy shelves are sturdy, limit the weight on the drywall.
Distribute the load across several anchors, and it will work without problems.
Far34
30 Dec 2020 10:16
If you hang heavy books or decorations, it’s better to use more fixing points and metal hollow wall anchors. These are more durable than plastic ones.
Using a wooden batten as a distribution element is excellent, provided the wall structure allows it.
