ᐅ How can I securely fasten Malm furniture in rental properties to comply with legal requirements?
Created on: 23 Sep 2019 08:37
noix60
I will soon be moving into a new rental apartment and want to securely attach my Malm furniture (wardrobe and dresser) to the wall to prevent accidents. However, I am unsure how to do this both legally and practically without causing issues with the landlord or risking problems when moving out.
My specific question is: What should I consider when securely and legally fixing Malm furniture in a rental apartment? Are there suitable methods that do not cause permanent damage, or should you always obtain explicit permission? Which fixing options are recommended to secure the furniture against tipping without damaging the wall?
Thank you very much for your advice!
Khalil
24 Sep 2019 13:02
Wow, great discussion so far! 🙂
I secured my Malm cabinets using the original IKEA anti-tip brackets and asked my landlord for permission by email beforehand. He was very relaxed because I made it clear that it was about safety.
You should definitely do the same – safety comes first, and if you are honest and transparent, there usually won’t be any issues!
Fingers crossed that everything works out for you! 🙂
Linavin
24 Sep 2019 16:44
Matthewt48 schrieb:
IKEA themselves provide anti-tip straps, which are often used
That’s a good point. However, it’s worth checking whether these safety devices are suitable for your wall type (e.g., drywall, brick). In some cases, special anchors are required, and not every wall can support them.
Also, what about liability if an accident happens despite the installation? Is the liability usually clearly settled when the landlord has given permission?
I believe we shouldn’t overlook these issues here, as safety and legal certainty must go hand in hand.
ladali
25 Sep 2019 08:18
Regarding liability: If the landlord has given written consent for the fixture, they generally assume responsibility for the modifications, as long as the installation does not exceed the agreed scope.
Without consent, the tenant can be held liable in case of damage, especially if improper installation was the cause.
In practice, Malm furniture is often secured directly to the wall using anti-tip straps. It is important to choose the appropriate type of wall plug (anchor) for the wall material and to document everything carefully. Alternatively, internal furniture stabilizers that clamp into the corners of the furniture are an option; these cause less wall damage but offer less protection against tipping.
A written agreement with the landlord significantly reduces risks.
Kabau
25 Sep 2019 11:07
Conclusion:
1. Obtain written permission from the landlord,
2. Use original IKEA anti-tip safety brackets,
3. Use wall anchors suitable for the wall type,
4. Document the installation,
5. Remove everything without leaving any residue when moving out.
This ensures you are on the safe side.
